Carburetor
26 Diagrams
1 Answer 0 Score |
Looking for lower transmission seals. ls on a honda fc600 tiller |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
FC600AC
Background and Identification
The Honda Mid Tine Tiller model FC600 is a tilling machine that is intended for use on garden or planting areas. It breaks up the soil as it goes by. This can aerate the soil, making it less packed and hard and more useful for planting. Tillers can also be used for weed control, as the tiller uproots the weeds when it goes by.
This is a mid tine tiller, which means that the engine is directly over the tines. This allows for better maneuverability when compared to front- or rear-tine tillers.
This tiller has several features intended to make it easier to operate and more effective. The tines, which break up the soil, are staggered from back to front, which reduces vibration. The tines can also be adjusted up or down to control how deep the tilling goes into the soil. Reviews on this tiller are generally positive, although one user had issues with the depth control and another said that this machine was slow compared to other models.
Technical Specifications
- Dimensions (LxWxH): 55.9" x 26.4"x 42.3"
- Dry Weight: 128 lbs.
- Tiller Type: Mid tine
- Tilling Width: 26"
- Tine Diameter: 13"
- Tine speed @max engine speed: 84 rpm
- Engine: Honda GX160
- Engine Displacement: 163cc
- Fuel capacity: 2.5 qt.
- Air filter: dual element
- Transmission Speeds: 1 - forward
- Transmission Type: chain and gear drive
Additional Information
***Part number for recoil starter is incorrect. 28400-Z4M-305ZD is correct part number
