3 Answers 8 Score |
How to fix grounded or dead boot huawei honor 3c? |
1 Answer 3 Score |
My phone is not charging through charging port |
5 Answers 4 Score |
Call log does not show in huawei 3c |
1 Answer 2 Score |
How can I fix the mic |
Background and Identification
The Honor 3C is an Android smartphone produced by Huawei and released in December 2013 for 3G, April 2014 for 4G, and August 2014 for 3C Play. It was the first mid-end phone of Huawei’s Honor subbrand and the first non-flagship Huawei phone to include a 720p display. It also includes the smallest 720p display from Huawei. The Honor 3C can be identified by model numbers H30-T00 and H30-U10.
The Honor 3C features a 5.0-inch display with a resolution of 720 by 1280 pixels. It includes dual-SIM capabilities, meaning it can house two Micro-SIM cards and operate with one while the other is in standby. It comes with 8 GB of internal storage and 2 GB of RAM. Its internal storage can be expanded using separate microSDHC cards, which can be inserted into the dedicated microSDHC slot. The phone features an 8-megapixel main camera and a five-megapixel selfie camera. The Honor 3C also includes a 2300 mAh removable battery, meaning its battery is not attached to the inside of the phone with any kind of permanent adhesive, making repair and replacement easier than for non-removable batteries.
The phone includes the Android three-button navigation system with a ‘home’ button in the center of the phone’s bottom bezel (indicated with a house-shaped button), a ‘back’ button on the left side of the ‘home’ button (indicated with an arrow pointing to the left), and a ‘show-all-open-applications’ button on the right side of the ‘home’ button (indicated by a square). The Honor 3C includes the name “Honor” in lowercase letters in the center of its backing.
Technical Specifications
Models: H30-T00, H30-U10
Release date: December 2013
Body:
- Dimensions and Weight: 139.5 x 71.4 x 9.2 mm (5.49 x 2.81 x 0.36 in), 140 g (4.94 oz)
- SIM: Dual SIM (Micro-SIM, dual stand-by)
Display:
- Type: IPS LCD
- Size: 5.0 inches, 68.9 cm2 (~69.2% screen-to-body ratio)
- Resolution: 720 x 1280 pixels, 16:9 ratio (~294 ppi density)
Platform:
- OS: Android 4.2.2 (Jelly Bean), EMUI Lite 2
- Chipset: Mediatek MT6582 (28 nm)
- CPU: Quad-core 1.3 GHz Cortex-A7
- GPU: Mali-400MP2
Memory:
- Card slot: microSDHC (dedicated slot)
- Internal: 8GB 2GB RAM
Main Camera:
- Single: 8 MP, f/2.0, 28mm (wide), AF
- Features: LED flash
- Video: 1080p@30fps
Selfie Camera:
- Single: 5 MP, f/2.4, 22mm (wide)
Sound:
- Loudspeaker: Yes
- 3.5 mm jack: Yes
Communications:
- WLAN: Wi-Fi 802.11 b/g/n, Wi-Fi Direct, DLNA, hotspot
- Bluetooth: 4.0, A2DP
- GPS: Yes, with A-GPS
- NFC: No
- Radio: FM radio
- USB: MicroUSB 2.0
Features:
- Sensors: Accelerometer, proximity, compass
Battery:
- Type: Li-Po 2300 mAh, removable
Miscellaneous:
- Colors: Black, White
