LCD / Display
1 Answer 0 Score |
[Honor 7x] Ear Speaker Not Working |
1 Answer 1 Score |
LCD replacement for Honor 7x? |
1 Answer 0 Score |
Honor 7A battery stuck 100% and charged |
1 Answer 0 Score |
Help! Honor gone Chinese |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
The Huawei Honor 7 Android smartphone was released by Huawei as part of their Honor sub-brand. The Honor 7 was released internationally with grey and silver bodies and 16 GB or 64 GB of internal storage. In China, one variant of the Honor 7 includes a gold-colored body with dual SIM capabilities and 64 GB of internal storage. The Indian variant includes only single-SIM capabilities. Its predecessor is the Honor 6, which was released in 2014.
The Honor 7 features an aluminum backing and frame with a 5.2-inch touchscreen display. It includes a 20-megapixel main camera and an 8-megapixel front camera. The Honor 7 also includes a fingerprint sensor and a ‘Smart’ button that can be assigned specific tasks to personalize the device. The international version features dual-SIM functionality, but only one SIM can be used if operated with an additional Micro-SD card for expanded storage. The Honor 7 includes accelerometer, gyro, proximity, and compass sensors, as well as fast-charging capabilities.
Reviews have found that the Honor 7’s rear-mounted fingerprint scanner does not always work flawlessly and the phone has sub-par battery life.
While the Honor 7 includes only 3 GB of RAM, it’s successor—called the Honor 8—includes 4 GB of RAM as well as a USB-C port.
Technical Specifications
Models: PLK-L01, PLK-AL10, PLK-UL00, PLK-TL01H
Release date: July 2015
Body:
- Dimensions and Weight: 143.2 x 71.9 x 8.5 mm (5.64 x 2.83 x 0.33 in), 157 g (5.54 oz)
- Build: Glass front (Gorilla Glass 3), aluminum back, aluminum frame
- SIM: Single SIM (Nano-SIM) or Hybrid Dual SIM (Nano-SIM, dual stand-by)
Display:
- Type: IPS-NEO LCD capacitive touchscreen, 16M colors
- Size: 5.2 inches, 74.5 cm2 (~72.4% screen-to-body ratio)
- Resolution: 1080 x 1920 pixels, 16:9 ratio (~424 ppi density)
- Protection: Corning Gorilla Glass 3
Platform:
- OS: Android 5.0 (Lollipop), upgradable to 6.0 (Marshmallow), EMUI 3.1
- Chipset: Kirin 935 (28 nm)
- CPU: Octa-core (4x2.2 GHz Cortex-A53 & 4x1.5 GHz Cortex-A53)
- GPU: Mali-T628 MP4
Memory:
- Card slot: microSDXC (uses shared SIM slot)
- Internal:16GB 3GB RAM, 32GB 3GB RAM, 64GB 3GB RAM
Main Camera:
- Single: 8 MP, f/2.4, 26mm (wide)
- Features: LED flash
- Video:1080p@30fps, HDR
Selfie Camera:
- Video: 1080p@30fps
Sound:
- Loudspeaker: yes
- 3.5 mm jack: yes
Communications:
- WLAN: Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
- Bluetooth: 4.1, A2DP, EDR, LE
- GPS: Yes, with A-GPS, GLONASS/BDS
- NFC: Yes
- Radio: Stereo FM Radio
- USB: MicroUSB 2.0
Features:
- Sensors: Fingerprint (rear-mounted), accelerometer, gyro, proximity, compass
Battery:
- Non-removable Li-Po 3100 mAh battery
- Charging: Fast charging 18W
- Stand-by: Up to 350 h (3G)
- Music play: Up to 8 h 20 min (3G)
Miscellaneous:
- Colors: Gray, Silver, Gold
- SAR EU: 1.13 W/kg (head) 0.52 W/kg (body)
