Battery
1 Answer 2 Score |
No image on screen |
1 Answer 0 Score |
My p10 plus is dead. |
1 Answer 0 Score |
New battery smelling sweet and fruity |
2 Answers 3 Score |
My p10 plus was fully dead |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
(VKY-AL00) China Dual SIM, (VKY-L09) Europe Single SIM, (VKY-L29) Global Dual SIM
Background and Identification
The Huawei P10 Plus Android smartphone was produced by Huawei as the higher-end phone to the Huawei P10. The P10 Plus was available in white, blue, gold, black, silver, rose gold, and green bodies. The P10 Plus includes a scratch-resistant glass front and an aluminum back and frame. The phone is also splash-resistant and includes a 3.5mm headphone jack. This device was not available in the United States.
The P10 and P10 Plus both feature main dual 20-megapixel and 12-megapixel cameras. The P10 Plus comes with a 5.5-inch QHD display, while the P10 has a 5.1-inch full HD display. The P10 Plus includes either 64 GB of internal storage and 4 GB of RAM or 128 GB of internal storage and 6 GB of RAM. The P10 variant contains 4 GB of RAM and 32 GB of expandable storage.
The P10 Plus includes a non-removable 3750 mAh battery with 18-Watt fast-charging capabilities. (A non-removable battery is one whose adhesive is permanent, making repair and replacement difficult.) The Plus features a front-mounted fingerprint sensor as well as an accelerometer, gyro, proximity, and compass sensors. It includes a single SIM and hybrid dual SIM capabilities, meaning it can contain a nano-SIM card and a second stand-by SIM card.
A TechRadar review praised the P10 Plus’s high-quality QHD screen and cameras but found that the phone’s navigation key was poorly designed.
Technical Specifications
Models: VKY-L29, VKY-L09, VKY-AL00
Release date: April 2017
Body:
- Dimensions and Weight: 153.5 x 74.2 x 7 mm (6.04 x 2.92 x 0.28 in), 165 g (5.82 oz)
- Build: Glass front (Gorilla Glass 5), aluminum back, aluminum frame
- SIM: Single SIM (Nano-SIM) or Hybrid Dual SIM (Nano-SIM, dual stand-by)
- Splash resistant
Display:
- Type: IPS-NEO LCD capacitive touchscreen, 16M colors
- Size: 5.5 inches, 81.5 cm2 (~71.6% screen-to-body ratio)
- Resolution: 1440 x 2560 pixels, 16:9 ratio (~540 ppi density)
- Protection: Corning Gorilla Glass 5
Platform:
- OS: Android 7.0 (Nougat), upgradable to Android 9.0 (Pie), EMUI 9.1
- Chipset: Kirin 960 (16 nm)
- CPU: Octa-core (4x2.4 GHz Cortex-A73 & 4x1.8 GHz Cortex-A53)
- GPU: Mali-G71 MP8
Memory:
- Card slot: microSDXC (uses shared SIM slot)
- Internal: 64GB 4GB RAM, 128GB 6GB RAM
- eMMC 5.1, UFS 2.0, or UFS 2.1
Main Camera:
- Dual:
- 12 MP, f/1.8, 28mm (wide), PDAF, Laser AF, OIS
20 MP B/W, f/1.8, 27mm (wide), 1/2.7"
- Features: Leica optics, dual-LED dual-tone flash, HDR, panorama
- Video: 4K@30fps, 1080p@60fps
Selfie Camera:
- Single: 8 MP, f/1.9
- Video: 1080p@30fps
Sound:
- Loudspeaker: yes, with stereo speakers
- 3.5 mm jack: yes
- 24-bit/192kHz audio
Communications:
- WLAN: Wi-Fi 802.11 a/b/g/n/ac, dual-band, DLNA, Wi-Fi Direct, hotspot
- Bluetooth: 4.2, A2DP, LE, aptX
- GPS: Yes, with A-GPS, GLONASS, BDS, GALILEO
- NFC: Yes
- Infrared port: Yes
- Radio: No
- USB: 2.0, Type-C 1.0 reversible connector
Features:
- Sensors: Fingerprint (front-mounted), accelerometer, gyro, proximity, compass
Battery:
- Non-removable Li-Ion 3750 mAh battery
- Charging: Fast charging 18W
Miscellaneous:
- Colors: Ceramic White, Dazzling Blue, Dazzling Gold, Graphite Black, Mystic Silver, Rose Gold, Greenery
