Display / LCD
2 Answers 2 Score |
My huawei y625 has Stuck in headset mode completely.how do I fix this |
1 Answer 1 Score |
My phone doesn't turn on after months discharged |
2 Answers 1 Score |
Huwawei Y6 Pro keeps shutting down. |
2 Answers 13 Score |
huawei Y625 speaker problem |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
The Huawei Y625 Android smartphone was produced by Huawei and released in April 2015. The Y625 model was released in black and white body colors.
The Y625 includes 4 GB of internal storage and 1 GB of RAM. The phone has Dual SIM capabilities, meaning that it can hold two Micro-SIM cards at a time and function with one SIM card on standby. The Y625 includes an 8-megapixel main camera with LED (light-emitting diode) flash capabilities and a 2-megapixel front-facing camera. The phone includes a removable 2000 mAh battery, meaning that the battery is not attached using any permanent glues or other fixtures and is more easily replaced than non-removable batteries.
The Huawei Y625 model includes a 3.5mm headphone jack and is built with an aluminum frame and a glass front and back. It has a 5.0-inch display with a resolution of 480 by 854 pixels. The Y625 phone includes the name “Huawei” printed in capital letters at the top of the phone’s front bezel, underneath the phone’s speaker and front-facing camera. The phone also includes three markings on the bottom bezel that act as a home button, back button, and switch apps button. The three-button navigation is the traditional Android navigation system.
Technical Specifications
Models: Y625-U32, Y625-U21, Y625-U51
Release date: April 2015
Body:
- Dimensions and Weight: 142 x 72.6 x 9.6 mm (5.59 x 2.86 x 0.38 in), 160 g (5.64 oz)
- Build: Glass front (Gorilla Glass), glass back, aluminum frame
- SIM: Dual SIM (Micro-SIM, dual stand-by)
Display:
- Type: IPS LCD capacitive touchscreen, 16M colors
- Size: 5.0 inches, 68.9 cm2 (~66.8% screen-to-body ratio)
- Resolution: 480 x 854 pixels, 16:9 ratio (~196 ppi density)
Platform:
- OS: Android 4.4.2 (KitKat), EMUI Lite 2.3
- Chipset: Qualcomm MSM8212 Snapdragon 200 (28 nm)
- CPU: Quad-core 1.2 GHz Cortex-A7
- GPU: Adreno 302
Memory:
- Card slot: microSDHC (dedicated slot)
- Internal: 4GB 1GB RAM
- eMMC 4.5
Main Camera:
- Single: 8 MP, AF
- Features: LED flash
- Video: 720p@30fps
Selfie Camera:
- Single: 2 MP
Sound:
- Loudspeaker: yes
- 3.5 mm jack: yes
Communications:
- WLAN: Wi-Fi 802.11 b/g/n, Wi-Fi Direct, DLNA, hotspot
- Bluetooth: 4.0, A2DP, LE
- GPS: Yes, with A-GPS
- Radio: FM radio
- USB: MicroUSB 2.0
Features:
- Sensors: Accelerometer, proximity
Battery:
- Removable Li-Po 2000 mAh battery
- Stand-by: Up to 310 h (2G) / Up to 250 h (3G)
- Talk Time: Up to 7 h 30 min (2G) / Up to 8 h 20 min (3G)
Miscellaneous:
- Colors: Black, White
