1 Diagram
1 Answer 0 Score |
pressure relief valve opening before time |
Models
0100211A
Background
The Husky Air Compressor 0100211A is a portable air compressor that is used for various applications such as home use, automotive requirements, and hobbyist activities. It is a compact and reliable source of compressed air, fulfilling the needs of these diverse applications.
This air compressor has a power rating of 120V, 60Hz AC, and a 1 HP oil-lubricated motor. The tank capacity is 2.6 gallons with a maximum pressure output of 135 PSI. The compressor has a pump displacement of 0.36 CFM and features a 6-foot power cord. In terms of dimensions, the unit measures 17 x 17 x 19 inches and weighs 32 lbs. It is equipped with a control panel that includes a pressure gauge, power switch with pressure regulator, and a quick connect coupler for attaching an air hose and accessories. It also has an integrated water drain valve to release moisture post-use. The air compressor is designed to be portable and can be easily used around the home or job site.
Technical Specifications
- Power: 120V, 60Hz AC
- Motor: 1 HP oil-lubricated
- Tank Capacity: 2.6 gallon
- CFM @ 40 PSI: 0.8
- CFM @ 90 PSI: 0.5
- Max Pressure: 135 PSI
- Pump Displacement: 0.36 CFM
- Power Cord Length: 6 ft
- Dimensions: 17 x 17 x 19 inches
- Weight: 32 lbs
Warranty
The Husky Air Compressor 0100211A comes with a 1-year limited warranty. This warranty covers any defects in the materials and workmanship of the product. Under the terms of the warranty, if your air compressor experiences a covered defect, Husky has the discretion to either repair or replace the damaged parts. However, it's important to keep in mind that standard wear items are not included in this warranty coverage. To claim the warranty, you will likely need to contact Husky directly, providing details of the issue and proof of purchase.
