1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
C301H
Background
The Husky C301H is an air compressor designed for various tasks, from home do-it-yourself (DIY) projects to automotive applications. This model is characterized by its 2.5-gallon oil-lubricated twin stack design, a configuration that aids in the longevity of the device by preventing overheating.
This air compressor is equipped with a 1.5 HP induction motor, and it can deliver a maximum pressure of 135 PSI, and an air delivery rate of 2.7 SCFM at 90 PSI. It operates on a 120V, 60Hz power supply. The device's dimensions are 20 x 10 x 20 inches and it weighs 45 lbs. It also has an oil-lubricated pump, which ensures quiet and cool operation. The device's design includes an easy-to-read pressure gauge, rubber feet to lessen vibration, and an on/off switch that automatically controls the motor based on preset tank pressure levels. The Husky C301H air compressor is utilized in various applications, like operating pneumatic tools (e.g., nail guns, staplers, spray guns), inflating tires, cleaning workshop equipment, and powering airbrushes and small paint sprayers. Maintenance primarily involves periodic oil level checks.
Technical Specifications
- Model Number: C301H
- Product Type: Air Compressor
- Motor: 1.5 HP induction motor
- Tank Capacity: 2.5 gallon
- Max Pressure: 135 PSI
- Air Delivery: 2.7 SCFM at 90 PSI
- Power Supply: 120V, 60Hz
- Pump Type: Oil lubricated
- Dimensions: 20 x 10 x 20 inches
- Weight: 45 lbs
Warranty
The Husky Air Compressor C301H comes with a 2-year limited warranty. This warranty coverage is specifically for defects in materials or workmanship that might occur under normal use conditions. However, it's important to note that wear parts such as air filters are not included in this warranty. To claim the warranty, you would typically need to provide proof of purchase and contact Husky Tools' customer service for further instructions.
