1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
F226VWD
Background
The Husky Air Compressor F226VWD is a vertical air compressor designed for various applications including home DIY projects, automotive service, and light industrial tasks. This product is equipped with a 2.6 HP, 120V motor and a 26-gallon tank. It can reach a maximum pressure of 135 PSI and delivers an air delivery rate of 5.7 SCFM at 90 PSI. Its pump is lubricated with oil, and it operates with a power cord of 6 feet in length.
The air compressor features a cast iron twin cylinder oil-lubricated pump, which ensures smooth and quiet operation. It comes with an aluminum tank designed vertically to occupy less floor space. The motor is protected against thermal overload. The machine has an automatic start/stop feature to conserve energy, maintaining tank pressure between 120-135 PSI when not in use and restarting when the tank pressure falls below 120 PSI. It includes dual pressure gauges that are easy to interpret, allowing users to monitor both tank and outlet pressure.
The Husky F226VWD air compressor can power various pneumatic tools such as nail guns, staplers, spray guns, impact wrenches, ratchets, drills, sanders, among others. It is suitable for tasks requiring moderate airflow such as automotive service, woodworking, construction, HVAC, and welding. The 26-gallon tank allows for extended runtimes between compressor cycling. Routine maintenance, including draining condensation from the tank and changing the oil, is necessary for optimal operation. Adequate ventilation is recommended to avoid overheating, and the compressor should be kept away from freezing temperatures.
Technical Specifications
- Model Number: F226VWD
- Product Type: Air Compressor
- Motor: 2.6 HP, 120V
- Tank Size: 26 Gallon
- Max Pressure: 135 PSI
- Air Delivery: 5.7 SCFM @ 90 PSI
- Pump Type: Oil-lubricated
- Power Cord Length: 6 ft
Warranty
The Husky Air Compressor F226VWD offers a 2 year limited warranty. This warranty encompasses defects that may be present due to materials used and workmanship. However, it's important to note that wear parts, such as valves and seals, are not included in this warranty coverage. Furthermore, the warranty becomes void in situations of misuse, abuse or improper maintenance. To claim the warranty, users will likely have to provide proof of purchase and contact Husky's customer service, though the exact process may vary and additional steps may be required. Always refer to the warranty information provided with the product or contact the manufacturer for specific instructions.
