IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown
1 Answer 2 Score |
Would anything happen to the storage |
2 Answers 0 Score |
What computer does this hard drive go in |
1 Answer 0 Score |
IBM 46C1748 Is it the same device |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
The Travelstar DJSA-220 (also known as the TravelStar 20GN) is a 20 GB hard drive released by IBM around the year 2000 (the manual for the hard drive was released in 2000 and revised in 2001). It is part of IBM’s TravelStar line of hard drives, specifically the DJSA line which includes sibling products called the DJSA-205, DSJA-210, DJSA-230, and DJSA-232. For each hard drive—including the DJSA-220—the final two digits of the model number show the number of gigabytes of data that the drive can store.
You can identify this hard drive by looking for identifying information on the sticker on the front of the device. This sticker should have the words “IBM Travelstar” and the model number “DJSA-220.”
This hard drive was manufactured in a standard 2.5-inch form factor. It is 9.5 mm thick. For data transfer and communication, the drive uses an ATA (also known as IDE) interface. After the release of the faster SATA interface in 2003, ATA was renamed to PATA, so you might see cables for this hard drive referred to as ATA, IDE, or PATA interchangeably. The ATA revision used by this hard drive can support data transfer at up to 66.6 Mbit/s. If you have data that you need to retrieve off this hard drive, you can find PATA adapters online as explained in this SuperUser question.
Technical Specifications
Disk
- 20 GB capacity
- 4200 rpm
Interface
- IDE/ATA connector
- 66.6 Mbit/s transfer speed (UDMA 66)
Dimensions
- 2.5-inch hard drive form factor
- 9.5 mm high
Additional Information
IBM Travelstar 20GN manual on ManualOwl
How to connect a PATA drive to a SATA motherboard on TechArena
