Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Background
The NUC13VYK is the Slim variant of Desk Mini PCs in the NUC 13 Pro Vivid Canyon lineup released in 2023. Other than visually, it is identical to the Intel NUC13ANK from the same year and processor generation. This is the last NUC marketed by Intel, predating ASUS' acquisition of the NUC line.
Identification
The Vivid Canyon NUC can be identified by the label underneath the unit. This label contains the exact model number, date of manufacture, and serial number for your NUC. If you are missing this label or the label is damaged, the only unique identifier compared to the Arena Canyon Slim NUC is the aluminum chassis and lack of VESA mount which make it the "Desk Edition." The "Slim" version is differentiated from the "Tall" version by its lack of 2.5-inch drive bay and back-panel expansion bay, resulting in its shorter height.
Technical Specifications
Processor Options:
- Intel Core i7-1370P with Intel vPro
- Intel Core i7-1360P
- Intel Core i5-1350P with Intel vPro
- Intel Core i5-1340P
- Intel Core i3-1315U
Graphics:
- Iris Xe Graphics (Core i7 and i5)
- Intel UHD Graphics for 13th Gen Intel Processors (Core i3)
Memory:
- 2x 260-pin 1.2 V DDR4 SODIMM slots (up to 64GB total capacity)
Storage:
- 1x M.2 PCIe Gen4 connector supporting M.2 22x80 (key type M) for NVMe only
- 1x M.2 connector supporting M.2 22x42 (key type B) for SATA, PCIe x1 or USB 3.2
- 1x SATA 6.0 Gbps combined data/power connector
Networking:
- Intel AX211 Wi-Fi 6E & Bluetooth 5.3
- Intel i226 2.5Gbps Ethernet
Ports:
- 2 x USB 4/Thunderbolt 4 Type C ports
- 3 x USB 3.2 Gen 2 Type A ports
- 1 x USB 2.0 Type A port
- 2 x USB 2.0 Internal Headers
- 2x HDMI ports capable of 4K@60Hz
- 1x RJ45 2.5Gbps Ethernet
- 1x 3.5mm stereo headphone/microphone combo jack
- 1x Kensington security lock slot
- 1x DC barrel plug for power
Dimensions:
- 117 mm x 112 mm x 37 mm (4.6 in x 4.4 in x 1.5 in) including feet
Power Supply:
- 120W (6V/20A) external power adapter
