2 Answers 0 Score |
How do I open machine to clean and maintain inside? |
1 Answer 0 Score |
Jura brew group motor stuck on top |
1 Answer 1 Score |
coffee grinds container flap inside the machine wont close,prevents |
1 Answer 0 Score |
Machine quit sucking water at end of descale program |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
Originally released in 2016 the Jura E8, model number 15097, is a Swiss made coffee machine offering a variety of specialties. This model produces 16 different types of specialties for coffee including espresso, hot water for tea, and a milk frother. The machine included a TFT interface giving users ease in navigating the machine’s different settings. The machine also includes self cleaning components and provides users with the ability to change out the milk spout for cleaning purposes. The machine also provides a CLERYL Smart system which is intended to maintain the best possible water quality for the machine.
Identification
This device is identified by its TFT interface with a silver and black Jura E8 logo below it. The E8 is located directly on the center on the front of the machine. The model number is located at the top right corner of the device.
Specifications
Model Number: 15097
Recalls: None
Depth: 17 inches
Height: 13.5 inches, access to bypass doser requires space.
Width: 11 inches
Watts: 1450W
Volts: 120V
Programmability: Dose, Milk Foam, Milk Volume, Shot Time, Temperature
Case Material: Plastic
Boiler Material: Stainless Steel-lined Aluminum
Cup Clearance: 2.5” to 4.5”
Reservoir Size: 2L
Cup Warmer: No
Brew Time 1:21
Boiler design: Thermoblock
Water Sources: Reservoir/Internal Tank
Auto Shut Off: Yes
Auto On: No
Aroma: Yes
One-Touch: Yes
Milk System: Capuccinatore/siphon
Capacity: 12 ounces
Bypass Doser: Yes
Material: Plastic
