12 Answers 6 Score |
Why won't my Keurig brew a full cup? |
1 Answer 0 Score |
Why does my coffee taste bad? |
1 Answer 2 Score |
Need disassembly instructions to replace Keurig K70 air pump |
1 Answer 0 Score |
Why won't my Keurig K70 Platinum start? |
Background
This model has a 72 oz water reservoir found on the left side of the coffee maker, along with a digital display of programmability on the top right side. The water tank easily detaches to clean and change the water. The automatic off feature allows the machine to turn off on its own. The K70 allows you to brew 5 different cup sizes of coffee. This model has been known to have issues when it comes to brewing a full cup size. Another possible problem could be that it's stuck on preheating, not allowing you to brew a cup of coffee. There are no known recalls on this model of Keurig coffee machine. The K70 brews quietly and can make a cup in less than a minute. It can also make other beverages such as tea, hot cocoa, etc. The model only works with room temperature water. It's different from the Keurig B70, since the B70 has a 60 oz reservoir smaller than the K70, while also being slightly smaller and weighing less.
Identification
This specific Keurig can be identified by its model number K70 listed on the bottom plate of the brewer and is a single cup brewer.
