Table of Contents
2 Diagrams
Background and Identification
The Kushlan Cement Mixer 1000DD-WB is a direct drive wheelbarrow style cement mixer that features a 1.5-horsepower electric motor. The mixer’s engine provides 28 rotations per minute on 120 Volts. The mixer can hold up to eight 80-pound bags of premixed concrete, or about 800 pounds. Kushlan generally recommends adding approximately five gallons of water for four-80-pound bags of premixed concrete.
The 1000DD features heavy-gauge steel handles that retract for easier storage. The mixer weighs 183 pounds without any cement in the drum. It features three steel blades with a mortar or concrete configuration. The mixer’s polyethylene drum is 5/16-inch thick and is resistant to dent, cracks, and rust.
The 1000DD model is a wheelbarrow style mixer, meaning that it has handles and wheels (somewhat like a wheelbarrow) for moving the mixer. It includes a heavy gauge black steel frame and bright orange polyurethane flat-free tires. The polyethylene drum is a bright orange color. The drum’s opening is 17 inches across and is 35 inches in diameter at its widest point. The stand’s wheels are black and the tires are either grey or bright orange. A black sticker with the name “Kushlan Products LLC” in white font is located on the side of the mixing drum.
Technical Specifications
Dimensions:
  • Assembled Depth (in.): 45 in
  • Assembled Height (in.): 48 in
  • Assembled Width (in.): 36 in
Details:
  • Concrete Tool Type: Mixer
  • Power Type: Electric
  • Product Weight (lb.): 183 lb
  • 10 cu. ft. polyethylene drum
  • Functioning Height: 70"
  • Functioning Length: 62".
  • Functioning Width: 45"
  • Functioning Weight: 192 lbs.
  • Drum Diameter: 36"
  • Drum Opening: 17”
  • Drum Gauge: 5/16”
  • Drum Rotations: 28 RPM
  • 3 Steel Blades with Mortar/Concrete Configuration
  • Heavy Gauge Steel Pipe Removable Handles
  • 13” x 4" Polyurethane Flat Free Tires with Ball Bearing Race
  • 120 Volt
Additional Information
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 13
Past 7 Days: 38
Past 30 Days: 173
All Time: 6,807
