Battery
1 Answer 1 Score |
Right side no longer working |
3 Answers 5 Score |
Why have they become too quiet |
1 Answer 0 Score |
Red light and no power |
1 Answer 0 Score |
My 18 month old headset |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
The Tone Infinim headset is shaped to go around the neck, with the earbuds attached to retractable cords. The earbuds have removable ear gels. When connected these claim to have a range of 33ft.
On the left side of the device is a covered micro USB port for charging. There are also buttons located on the top for “Call” and “Play/Pause”. There is a “Power” button, as well as specific buttons made to release the headphones and allowing you to pull the cord to extend the earbuds to reach your ears. Lastly, there’s a button to adjust volume. There is a small pad on the side of these that can be removed to uncover a hidden screw, so it is possible to open the device.
Inside is a 3.7 volt lithium-polymer battery. There are small LED indicator lights for things like “Bluetooth pairing mode” or whether the power is on or off.
The device has a metallic finish. These are reportedly vulnerable to water damage, as they lack any kind of protection from moisture or weather.
These were offered with a 1 year warranty.
This model has been discontinued by the manufacturer.
Technical Specifications
- Weight: 1.8 ounces
- Colors: Black, Silver, Rose Gold
- Model: HBS-910
- Battery 210mAh
- Manufacturer: LG
- Width: 5.7 in
- Depth: 0.6 in
- Height: 6.9 in
- Weight: 1.8 oz
