1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
11205
Background
The Lincoln Electric Welder 11205 is a welder produced by Lincoln Electric. This machine is designed for a variety of users including hobbyists, farmers, and those who wish to have a versatile welder for home use. As an arc welder, it is intended to work for a variety of welding processes.
The Lincoln Electric Welder 11205 operates on a power input of 120 V, 60 Hz, with an output range of 30-105 A and a duty cycle of 20% at 105A. It is capable of performing Stick (SMAW) and flux-cored (FCAW-S) welding processes. The welder has a weight of 19 kg and dimensions of 533 x 274 x 457 mm. It is designed to be portable, with a top carry handle for easy transportation. The welder also features a quick-change drive roll for switching between solid wire and flux-cored wire. It is equipped with thermal overload protection to prevent overheating and an infinitely variable amperage control dial for fine tuning weld output. The user interface is straightforward, with two large dials for easy amperage control. The welder's case is made of metal, providing durability in workshop conditions. This welder includes a welding cable, work clamp, and a sample spool of flux-cored wire.
Technical Specifications
- Model Number: 11205
- Product Type: Welder
- Power Input: 120 V, 60 Hz
- Output Range: 30-105 A
- Duty Cycle: 20% at 105A
- Welding Processes: Stick (SMAW), flux-cored (FCAW-S)
- Weight: 19 kg
- Dimensions: 533 x 274 x 457 mm
Warranty
The Lincoln Electric Welder 11205 is accompanied by a warranty of 3 years, which covers parts and labor. The warranty is specifically designed to protect against defects in materials and workmanship. However, it should be noted that items that experience normal wear, such as contact tips, nozzles, and drive rolls, are not included in the coverage. To claim the warranty, the original retail purchaser should provide proof of purchase.
