6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
11058
Background
The Lincoln Electric Welder 11058 is a welder designed for hobbyists and those looking for a tool for basic welding projects. It is a MIG flux core wire feed welder, with a power source of 120V/240V AC single phase and an output range of 30A-88A. It supports MIG (GMAW) and flux core (FCAW) welding processes. The wire feed speed is 50-500 ipm, and the welder itself weighs 19 lbs with dimensions of 15 x 8 x 12 inches.
In terms of features, the Welder 11058 includes continuous voltage control to tailor the arc performance, four output ranges to adjust the amperage for different material thicknesses, and a drive system for smooth wire feeding at various speeds. It also has a thermal overload protection mechanism to avoid overheating and damaging internal components. The control panel at the front of the machine includes a gauge for voltage, amperage, and wire feed speed settings, with clearly labelled controls and switches for user convenience. The welder comes with a 6-foot MIG gun, work clamp, and a sample spool of flux core wire. The Welder 11058 is designed for light duty welding on materials no thicker than 1/4 inch, such as mild steel, stainless steel, aluminum and chrome alloys. Its portability makes it suitable for basic repairs and projects around the home, though it is not intended for intensive industrial use.
Technical Specifications
- Model Number: 11058
- Product Type: MIG flux core wire feed welder
- Power source: 120V/240V AC single phase
- Output range: 30A-88A
- Welding processes: MIG (GMAW), flux core (FCAW)
- Wire feed speed: 50-500 ipm
- Weight: 19 lbs
- Dimensions: 15 x 8 x 12 inches
Warranty
The Lincoln Electric Welder 11058 comes with a 3-year warranty provided by Lincoln Electric. This warranty covers parts and labor and is applicable to the original purchaser only, meaning it is non-transferable. The warranty also covers normal wear items such as MIG gun consumables, but these are only covered for a period of 90 days. It is important to note, however, that the warranty does not cover any damage resulting from misuse or abuse of the welder.
