6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
K2514-1
Background
The Lincoln Electric Welder K2514-1 is a wire-feed welder. This welder is specifically designed for various tasks including do-it-yourself projects at home, hobbyist activities, farm repairs, and basic automobile body welding. The device makes use of a 120V DC power source and operates at a voltage of 110 Volts. It uses the MIG welding installation method. The package contains the welder unit itself, a welding gun, a work cable with a clamp, a sample spool of .030" SuperArc welding wire, and E7018 stick electrodes.
The Lincoln Electric Welder K2514-1 has notable features that contribute to its functionality. It has a continuous wire feed speed control and a numeric tension indicator that is easy to adjust, which allows for quick setup by the user. The welder is equipped with a .030" SuperArc welding wire spool which is used for welding mild steel. The device has thermal overload protection to avoid overheating. The welder is designed to be portable and comes with a handle for convenience in carrying. Its compact size adds to its portability. The K2514-1 is capable of welding mild steel with up to 1/4" thickness. This device is suitable for light-duty welding projects, repairs, fabrication, and hobby work. It operates by plugging into a standard 120V power outlet. The flux core wire feature allows it to be used without shielding gas for most applications.
Technical Specifications
- Manufacturer: Lincoln Electric
- Part Number: K2514-1
- Weight: 71 lbs
- Dimensions: 18 x 15 x 16 inches
- Model Number: K2514-1
- Power Source: 120V DC
- Voltage: 110 Volts
- Installation Method: MIG welding
- Included in Box: Welder unit, welding gun, work cable with clamp, sample spool of .030" welding wire, stick electrodes
Warranty
The Lincoln Electric Welder K2514-1 comes with a warranty that lasts for a period of 3 years. This warranty coverage includes defects that may arise due to issues in materials and workmanship. However, the warranty does not extend to normal wear items, which include but are not limited to contact tips, nozzles, drive rolls, and liners. Additionally, any damages that result from improper use or maintenance of the welder are not covered under the warranty.
