6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
K2515-1
Background
The Lincoln Electric Welder K2515-1 is a MIG welder designed for various welding projects, including those related to farm, light fabrication, automotive, and home. The machine operates on a power source of 230V AC and can handle a maximum metal thickness of 3/16" with MIG welding and 1/2" with flux-cored welding. The welder's dimensions are 20 x 15 x 16 inches, and it weighs 67.5 lbs.
This welder model is equipped with a 2 knob tapped control for easy adjustment of welding parameters. It is capable of welding thin steel, stainless steel, and aluminum sheet metal with MIG, as well as thicker steel with flux-cored welding. The welder also offers two heat settings and a wire feed speed control for selecting the optimal parameters. It can weld mild steel up to 3/16" thickness using MIG welding, and up to 1/2" thickness using gasless flux-cored welding. With a 230V power supply, the welder is suitable for heavy duty welding.
Technical Specifications
- Manufacturer: Lincoln Electric
- Model Number: K2515-1
- Power Source: 230V AC
- Max Metal Thickness (MIG welding): 3/16"
- Max Metal Thickness (flux-cored welding): 1/2"
- Weight: 67.5 lbs
- Dimensions: 20 x 15 x 16 inches
Warranty
The Lincoln Electric Welder K2515-1 comes with a 3-year warranty provided by the manufacturer, Lincoln Electric. This warranty covers any defects in materials and workmanship, ensuring that the product you received is of the highest quality. However, certain limitations may apply. To claim the warranty, it is recommended to refer to the official warranty details provided by Lincoln Electric. This may involve contacting the manufacturer directly or through the authorized dealer where you purchased the product. Make sure to keep your purchase receipt as it might be required to validate your warranty claim.
