DLP Chip
1 Answer 0 Score |
How to get tv to 1080p |
1 Answer 1 Score |
Can you replace the Gold ribbon cable if it breaks? |
1 Answer 0 Score |
Replaced Lamp TV shuts down still? |
1 Answer 0 Score |
TV Cannot learn new HDMI chords |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
• Energy Star 3.0 Qualified
• 3D ready
• Smooth 120™
• 1080p DLP® Display
• Plush 1080p 5G Improved 12-bit Processing
• Perfect Color™
• Video Modes:
Brilliant/Bright/Natural/Game/Advanced
• Improved Video Noise Reduction
• UltraThin™ Frame
• Exclusive 6-Color Processor™
• 3 HDMI 1.3a™
Deep Color™ (36-bit) & x.v.Color™
• Side Component Input
• 2 Rear Component Inputs
• New Jade Activity Based User Interface
Screen Size
73-inch
Aspect Ratio
16:9 (widescreen)
Height
43.6˝
Width
65.2˝
Depth
17.9˝
Height On Matching Base
60.2˝
Matching Base Model
MB-S73A
Weight
92.8 lbs.
Power Consumption
Operating Standard
218 Watts
Standby
0.6 Watts
Optical System Display Type
DLP®
HDTV Resolution*
1080p
Lamp Power
180 watts
Video Performance
Mitsubishi Exclusive 6-Color Processor™
Yes
Plush 1080p 5G 12-Bit Video Processing and video format conversion
Yes
HDMI 1.3a™
Deep Color™ (36 bit) and x.v.Color™
Yes
PerfectColor™
Yes
Yes
New Advanced Video Calibration Mode
Yes
3D Ready**
Yes
Picture Format Modes (4:3 sources)
6
Picture Format Modes (16:9 sources)
3
User Controls
Easy Connect™
Yes
ChannelView™
Yes
A/V Adjustment (Memorized By Input)
Yes
Color Temperature Control (By Input)
Yes
Video Modes:
Yes
Audio
Internal Loudspeakers
2
Speaker Size
5.5˝ x 2.5˝
Output Power (watts/ch.)
10 watts
Level Sound (dynamics limiter)
Yes
Digital Output (PCM) for All Analog Sources
Yes
Tuning
Combined Tuner Analog/Digital/Cable
(in the clear)
Antenna (RF) Inputs
Side Inputs
Component/Composite Combined
Rear Inputs
(480i/480P/720P/1080i)
2
Stereo Audio Input for PC/DVI Source
HDMI™ Inputs
3
480i, 480p, 720p, 1080i (60Hz)
Yes
1080p (24Hz, 30Hz, 60Hz)
Yes
HDMI™ Digital PC Compatibility
640 x 480, 898 x 480, 800 x 600,
1064 x 600, 1024 x 768, 1280 x 720, 1365 x 768, 1280 x 1024 @ 60Hz
Yes
1920 x 1080 @ 24Hz, 30Hz, 60Hz
Yes
Outputs
Stereo Audio Output
Digital Audio Output (Dolby® Digital / PCM)
3D IR Emitter **
Remote Control customization Features
Direct IR Input Selection
Yes
Direct IR Format Selection
Yes
Independent IR Power ON / OFF
Yes
