Specifications
Sound Generator
Data format: 16-bit linear WAV
Sampling rate: 44.1 kHz
Memory: 2MB standard, expandable to 32MB with 72pin SIMMsn
Preset sound memory: 8MB FlashRom option (FMX008M)
Recording time: 21.9 sec. mono / 10.9 sec. stereo (2MB), around 6mn mono / 3mn stereo (32MB))
Polyphony: 32-voice
Filters: 1 dynamic resonant 12dB/octave low-pass filter per voice
Number of active programs: 4 (with up to 64 pads per program)
Maximum samples in memory: 256
Sequencer
Capacity: 300,000 notes
Resolution: 96ppq
99 Sequences
64 Tracks per sequence
32 MIDI output channels (16 channels x 2 output ports)
Song mode: 20 songs, 250 steps per song
Simultaneous playback of a second sequence
MIDI Sync: Master/Slave, MIDI Clock, MTC, MMC
Drumpads
16 velocity and pressure sensitive pads
4 pad banks
16 Levels: Velocity, Tuning
Automated Pad Mixer (Level and Pan)
Note variation slider controls Level, Pitch, Filter Cutoff, Attack, Decay
Track Mute and Next Sequence features for live performance
Connections
Record Input (L and R): jack x 2, balanced
Digital Input: RCA x 1, SPDIF (option)
Stereo Output (L and R): jack x 2, unbalanced
Individual Outputs: jack x 8, unbalanced (option)
Headphone Output: stereo jack x 1
Digital Output: RCA x 1, SPDIF (option)
MIDI: 2 x MIDI In and 2 x MIDI Out
SCSI: 50pin high density connector
General
Display: 248x60 dot graphic tilting LCD
Multi-Card drive (MCD model only): Compact Flash, Memory Stick, Smart Media, Secure Digital
Standard accessories: 1x CD-ROM sound library, Power cable
Power: 100-240V AC, 50/60Hz
Consumption: 23W
Dimensions (H x W x D):
4.17" x 15.95" x 8.99" (106mm x 405mm x 331mm)
Weight: 12.13lbs (5.5kg)
Optional Accessories
IB-M208P: 8 individual output and digital I/O board
EB16: Multi-effects processor board (4 simultaneous FX)
FMX008M: 8MB Flash ROM board
IC-M2TC: SMPTE IC
MPC 2000XL
Oren Levy
1 Reputation
0 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 28
All Time: 6,018
