1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
4112H
Background
The Makita 4112H is an industrial grinder intended for cutting steel, concrete, and masonry materials with a dry cutting diamond blade. It incorporates 'SJS' technology to avoid kickback when blade jamming occurs. This tool is suitable for a range of applications, such as builders, fire/rescue, maintenance, remodelers, roofers, masons, and pipe fitters.
Technical Specifications
- Blade Diameter: 12" (305 mm)
- Arbor: 1" (25.4 mm)
- Maximum Cutting Depth: 3-15/16" (100 mm)
- No Load Speed: 5,000 RPM
- AMPS (120V): 15.0 A
- Overall Length: 25-1/2" (648 mm)
- Net Weight: 25.1 lbs (11.4 kg)
