1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
9566CV
Background
The Makita 9566CV is a 6" SJS™ Cut-Off/Angle Grinder designed for stone grinding, polishing, and cutting. It features a 13 AMP motor with a variable speed control dial, allowing customization to the task at hand. The grinder is built with Makita's innovative SJS™ mechanical clutch system, which protects the gears and prolongs tool life. Additionally, it has a soft start, labyrinth construction for motor protection, and protective zig-zag varnish to seal the motor and bearings from dust and debris. The dimensions of the grinder are H 4 in, W 5.5 in, D 11.75 in, with a 6" max wheel diameter and 1/4" max wheel thickness.
Technical Specifications
- Motor: 13 AMP
- Variable Speed Dial: 4,000 - 10,000 RPM
- Max Wheel Diameter: 6 inches
- Max Wheel Thickness: 1/4 inch
- Dimensions: H 4 x W 5.5 x D 11.75 inches
- Weight: 5.3 lbs
- Spindle Type: 5/8" - 11 UNC
- Switch Type: Body grip/slide
