1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Background
The Makita 9566PC is a 6" SJS™ Paddle Switch Cut-Off/Angle Grinder suitable for various applications such as cutting ferrous metal, removing paint and rust, maintaining shipyards and heavy machinery, polishing metal, grinding steel, repairing automobiles, cutting brick and masonry, and restoration work. This grinder is suitable for welders, fabricators, plumbers, masons, electricians, automotive technicians, stone and tile workers, HVAC, and general contractors. It features Makita's innovative SJS™ mechanical clutch system, which helps protect the gears for extended tool life. Moreover, it is equipped with a 13 AMP motor that delivers 9,000 RPM.
Technical Specifications
- Wheel Diameter: 6"
- AMPS: 13
- No Load Speed: 9,000 RPM
- Spindle Type: 5/8" - 11 UNC
- Lock-On Switch: No
- Lock-Off Switch: Yes
- Switch Type: Body grip/paddle
- Overall Length: 12-1/8"
- Net Weight: 5.5 lbs.
- Variable speed dial: No
- Power Type: Corded
- Bind-Up Control: Yes
Makita 9566PC Angle Grinders Tool Flyer
