3 Diagrams
1 Answer 0 Score |
stopped running in use. now will not turn on |
Documents
Models
UC4051A
Background
The Makita 16-inch Electric Chain Saw (model UC4051A) is a corded electric chainsaw with a chain speed of 2,900 feet per minute. The chainsaw weighs 12.3 pounds and has a 16-inch guide bar that has a maximum cutting diameter of 16 inches. It also features an anti-vibration handle for operator comfort.
The UC4051A model includes an automatic chain oiler and a transparent oil reservoir window for users to easily check their machine’s oil level. It also has a trigger switch with ‘soft start’ for smoother start-ups. The UC4051A model features a lock-off button that prevents accidental machine activation and a front handguard to protect the operator from debris. This model includes a large metal spike bar at the base of the guide bar, designed to increase productivity. Chain and blade adjustments can be made without tools and a cord hook is included to prevent unintended power disconnection. The chainsaw’s oil tank can hold 6.8 fluid ounces.
Because the UC4051A model is electric, it produces zero emissions and has reliable start-ups. This model runs at 14.5 Amps of current. The chain runs at 14.5 meters per second and contains 56 drive links.
Identification
Makita chainsaws can be identified by their teal color and the name “Makita” printed in lower-case letters on the guide bar and side of the machine. Other identifying information, including the model number, is printed in grey text on the guide bar of the UC4051A model.
Technical Specifications
Dimensions:
- Bar Length (in.): 16 in.
- Chain Size: 16 in.
- Maximum Cut Diameter (in.): 16
- Maximum extension cord length (ft.): 50
- Overall Length: 19-7/8”
Details:
- Amperage (amps): 14.5
- Chain Pitch: 3/8 in.
- Chain Speed: 29000 FPM
- Chain Speed (mps): 14.5
- Chainsaw Bar Size: Medium
- Chainsaw Type: Hand Chainsaw
- Cord Length (ft.): 1
- Drive Links: 56
- Features: Antivibration Handle, Chain Brake, Tool-Less Chain Tensioning
- Filter Type: No Filter
- Gauge: .050
- Handle Type: Rear Handle Chainsaw
- Included: Chain
- Power Type: Corded Electric
- Product Weight (lb.): 12.3lb
- Torque Maximum (Nm): 0.0
- Oil Tank Capacity: 6.8 oz.
