1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
4114Q
Background and Identification
Makita Power Cutter Saw Model 4114Q is a corded electric power cutter that features Super Joint System (SJS) technology. SJS is a mechanical clutch system that allows the driveshaft to slip if the cutting wheel is forced to stop. This feature prevents motor and gear damage in grinders. The cutter does not need to be restarted after the wheel stops because the SJS mechanism is mechanical, not electronic. The cutter can be positioned from 0 degrees to 80 degrees and the operating angle does not affect the cutting depth of the wheel.
The 4114Q model weighs 23.8 pounds. It includes a 14-inch diamond cutting blade designed for concrete cutting. It is powered by a 15 Amp motor with 3,800 RPM. The 4114Q model also features a removable base for closet cuts and an adjustable tool base that can cut up to five inches deep. It includes a built-in vacuum attachment port and a rubber shield designed to reduce dust and keep debris away from users and the motor. This power cutter also includes an AC/DC switch so that it can be used with an alternative power source.
The Makita Power Cutter Saw Model 4114Q includes a large cutting blade with a blade guard and a handle. It can be identified by the name “Makita” in lowercase letters on the cutter guard. Both the guard and the “Makita” name are a silver color. The cutter’s handle is black with a teal motor covering. The “Makita” name is also printed on the teal part of the saw’s handle.
Technical Specifications
- Blade Diameter: 14"
- AMPS: 15
- No Load Speed: 3,800 RPM
- Max. Cutting Depth (14" diamond blade) : 5"
- Max. Cutting Depth (14" cut-off wheel) : 5"
- Arbor: 1"
- Overall Length: 26-1/2"
- Net Weight: 23.8 lbs.
- GFCI plug: No
- Includes dust extraction guard: Yes
- Power Tool Product Type: Corded
- Power Type: Corded
