5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
DPC7321
Background
The Makita DPC7321 is a gas-powered cutter designed for use in various cutting applications. Its features make it suitable for use in a multitude of conditions, with a reinforced aluminum blade guard that allows for versatile positioning, and a cutting arm that can move from a center position to a flush position. This makes it ideal for cuts directly next to curb edges, walls, or directly above the ground. The product also includes an improved ignition system that uses a large flywheel and rare earth magnets to provide more power.
The Makita DPC7321 is designed with operator convenience in mind, with a starter grip and decompression valve located on the same side for faster starting. The on/off choke operating switch is on a single lever for easier operation. It also features cushioned operator grips with four rubber buffers to absorb vibration, increasing operator comfort. A water-kit is assembled to the saw, which can be used with a garden hose, gravity tank, or pressure tank. The product also boasts improved exhaust emissions.
The product's specifications include a 14-inch wheel size, a maximum RPM of 9350, and a tool weight of 22 pounds. It has a cut depth of 4.8125 inches and a horsepower of 5.6 hp/4.2 kW. The arbor hole is 1 inch and the overall weight of the product is 29.2 LB.
Technical Specifications
- Wheel size: 14 in
- Engine displacement: 4.5 in3
- RPM [max]: 9350 rpm
- Tool weight: 22 lb
- Cut depth: 4.8125 in
- Horsepower/kilowatts: 5.6 hp/4.2 kW
- Arbor hole: 1 in
- Weight: 29.2 lb
- EAN or UPC: 88381317047
