Back Cover
7 Answers 2 Score |
Phone not saying turbo charger connected |
2 Answers 0 Score |
How does the loudspeaker connect to the phone? |
1 Answer 0 Score |
Has anyone replace the battery of a Motorola Edge Plus? |
1 Answer 4 Score |
screen replacement Motorola Edge Plus |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
XT2061-3
Background
The Motorola Edge Plus is an android smartphone made by the Lenovo subsidiary Motorola in the year 2020. It was initially released exclusively in the US on May 14th, 2020, with an international release happening on May 19th. It initially retailed for $800. A non-plus version was released afterward on May 29th, 2020, the biggest difference between these versions is that the Moto Edge+ gets a slightly larger screen at 6.7 inches versus 6.6 inches on the Edge. A new model came out on June 20th, 2024, and sported a larger battery and an improved processor. Common complaints about the device include fragility and touchscreen unresponsiveness.
Identification
The Motorola Edge Plus 2020 sports a screen that wraps around to the back and a back panel that comes in either a smoky blue or red color. There are three cameras on the back vertically stacked. The dimensions are 161.07 x 71.38 x 9.6mm. The model number is located to the left of the charging port
Troubleshooting
If you want to diagnose whether your problem is software or hardware related—including backing up and restoring your device—download the Rescue and Smart Assistant app.
Technical Specifications
Dimensions: 161.07 x 71.38 x 9.6mm
Weight: 203g
Colors: Thunder Gray, Smoky Sangria
Operating system: Android 10
Processor: Qualcomm Snapdragon 865 Mobile Platform octa-core processor, Adreno 60 GPU
RAM: 12GB
Storage: 256 GB
Battery: 5000mAh, two day battery life
Ports:
- Type-C port (USB 3.1)
- 3.5mm headset jack
Display:
- 6.7" Endless Edge display
- OLED
- DCP-P3 color space
- HDR10+
Rear Camera
- 108 MP
- 1/133" sensor size
- 6k UHD (30 fps)
- UHD (30 fps)
- FHD (30/60 fps)
Front Camera
- 25MP sensor
- FHD (30fps)
- HD (30fps)
- Slow motion FHD (120fps)
- HD (240 fps)
Sensors
- Accelerometer
- Gyroscope
- Proximity
- Ambient Light
- Sensor Hub
- Fingerprint Reader
- Barometer
- Magnetometer (compass)
Connectivity
- 802.11 Wi-Fi 6
- Bluetooth 5.1
- 5G: sub-6GHz
Additional Information
Motorola Edge Plus Specifications
