Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Background and Identification
The Nellcor N-85 is a portable pulse oximeter made by Mallinckrodt’s Nellcor division. It is sometimes called the OxiMax N-85 pulse oximeter. Pulse oximeters are non-invasive devices used to monitor a patient’s oxygen saturation. The Nellcor division focuses mainly on producing pulse oximeters and oxygen monitors.
The N-85 model measures oxygen saturation, end-tidal carbon dioxide, respiratory rate, and pulse rate values. It can be used for continuous monitoring or spot-checking for bedside monitoring and emergency situations. It is suitable for use with adult, pediatric, and neonatal patients. A low sample flow rate of 50 mL per minute allows the device to monitor a wide range of patients. This pulse oximeter is compatible with OxiMax sensors.
The Nellcor N-85 is powered by a rechargeable Nickel Metal Hydride battery pack. It is operated using a four-key keypad. Two seven-segment LED digital displays present oxygen saturation and end-tidal carbon dioxide levels. An LCD graphic display shows the patient’s respiratory rate, pulse rate, and plethysmographic waveform.
The model name “N-85” is printed in the upper left-hand corner of the monitor’s front face. The name “NELLCOR” is printed in capital letters in the bottom center of the device’s front face. The N-85 model weighs under two pounds.
Technical Specifications
- Dimensions: 8.11" H x 3.46" W x 2.06" D
- Displayed Parameters: CO2 and plethysmographic waveforms, ETCO2, SpO2, pulse rate, respiration rate, trend data.
- Display Range: 0-99 mm Hg (0-13.2 kPa and 0-13 vol% at sea level)
- Sampling Rate: 50 +- 7.5 mL/min
- Warm-Up Time: 30 seconds typical, reaches steady-state accuracy 20 minutes after power-up.
- Accuracy: 0-38 mm Hg +-2 mm Hg, 39-99mm Hg +-5% of reading.
- Respiration Rate: 0-150 breaths/minute.
- Battery Type: Rechargeable NiMH.
- Battery Capacity: 4-7 hours. Recharges in approximately 4.5 hours.
