Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
This Nikon camera with a detachable lens was released in 2013. Compact and lightweight, the J3 is ideal for everyday use without weighing you down. The ability to switch out lenses between any of the 1-series mounts is a great benefit of this camera, and it has allowed for easy swapping.
Some users have found faults with this model. The mode dial at the top of the camera uses abnormal symbols, and the camera's menu is unnecessarily intensive. According to users, the menu is too divided, which does not allow for very quick access of the needed features. Despite these flaws, it is still an upgrade from the limited menu the J2 offered.
The J3 has a higher image resolution than previous models at 14.2 megapixels, and it can take 1080p video. When compared to the previous model, the J2, this camera boasts a light sensitivity twice as high. It uses a rechargeable 1020 mAh EN-EL20 lithium ion battery pack.
Identification
To differentiate it from previous models, note these key differences. On the front of the device, there should be the characters "J3" on the top right, and a lens detach button below the lens on the right. The J3 has the mode dial on the top, not the back. The side loops to connect a strap are vertical as opposed to horizontal.
Additional Information
Buy used on Amazon
The device's Wikipedia page
The manufacturer's reference guide
Austin Lackey
479 Reputation
4 Guides authored
USF Tampa, Team S11-G4, Passmore Fall 2017 Member of USF Tampa, Team S11-G4, Passmore Fall 2017
USFT-PASSMORE-F17S11G4
3 Members
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 51
All Time: 3,105
