Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Background and Identification
The Novametrix Mars Tech Model 2001 is a pulse oximeter manufactured by Novametrix Medical Systems. It is sometimes simply called the Novametrix Model 2001. Pulse oximeters are non-invasive devices used to monitor a patient’s oxygen saturation. Novametrix was a producer of airway pressure monitors, transcutaneous blood gas monitors, pulse oximeters, capnographs, respiratory mechanics monitors, and volumetric carbon dioxide monitors. Novametrix is now owned by Philips Respironics, a medical device conglomerate.
The Novametrix Mars Tech Model 2001 provides measurement, display, and alerts for the patient’s pulse rate and functional pulsatile oxygen saturation. The 2001 model can be powered either by its internal rechargeable battery or by AC power (line voltage). A bright Cold Cathode Display (CCD) presents the numerical and waveform information. Users can adjust the display’s contrast to optimize viewing angles. Users can choose to indicate the presence of a pulse by a “beep.” 24-hour trends for pulse rate and oxygen saturation are updated every eight seconds.
The 2001 model is compliant with requirements for the year 2000. This model includes the name “Model 2001 Pulse Oximeter” printed in the upper right-hand corner above the device’s graphic display. The name “Novametrix Medical Systems, Inc.” is printed in the upper right-hand corner of the device’s front face. The Mars Tech company logo is included in the device’s upper left-hand corner. Control buttons are located underneath and to the sides of the display.
Technical Specifications
Oxygen Saturation
- Range: 0-100%
- Accuracy: 70-100% +- 2% (1 standard deviation), 0-69% unspecified (Approximately 68% of the observations are within the accuracy claim.)
- Display Resolution: 1%
- Averaging Time: fixed at 8 seconds
- Audible SpO2 Trend Feature: Pitch of (user selectable) Pulse Rate “beep” tracks the SpO2 value (i.e., decreasing SpO2 values are signaled by lower-pitched “beeps”).
- Settling Time: Display settles to within 1% of the final reading less than 15 seconds after the sensor is properly applied.
- Alerts: Continuously displayed. Menu selectable high and low limits (100-50). Visible alarm is immediate. Audible alarm occurs after 10 seconds of continuous violation of the set limit, or immediately. Limit values are retained in memory when monitor is turned off, or the monitor can be set to use its default settings each time it is turned on.
Pulse Rate
- Range: 30-250 beats per minute (bpm)
- Accuracy: +- 1% of full scale (1 standard deviation) (Approximately 68% of the observations are within the accuracy claim.)
- Display Resolution: 1 bpm
- Alerts: Continuously displayed. Menu selectable high and low limits (249-30 or Off). Visible alarm is immediate. Audible alarm occurs after 10 seconds of continuous violation of the set limit or immediately. Limit values are retained in memory when monitor is turned off, or the monitor can be set to use its default settings each time it is turned on.
General
- Operating Conditions: 50-104 °F (10-40 °C), 0-90% relative humidity, non-condensing
- Transport/Storage Conditions:-10 to +55 °C (14-131 °F), 10-95% relative humidity, non-condensing
- Weight: 7 lbs 5 oz. (3.32 kg)
- Dimensions: Height, 3.3 inches (8.38 cm) Width, 9 inches (22.86 cm) Depth, 8 inches (20.32 cm)
- Power: 100-120/200-240 VAC, 50/60 Hz
- Fuse Rating: U.S.A.: 0.5 A, 250 V, Slo-Blo (x2) European: T 250 mA/250 V (x2)
- Battery: Type, lead-acid gel-cell. Battery Life, 3 hours.
- Note: Excessive alerting reduces battery life. When 15 minutes of battery life remain, the (low battery) indicator illuminates. When the battery becomes exhausted, the monitor display shuts down. Connect to AC power to recharge battery. Recharge Time, battery fully recharged in 12-15 hours maximum.
Additional Information
Novametrix Mars Tech Model 2001 on eBay
