Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Background and Identification
The Datex-Ohmeda Centiva/5 is a critical care ventilator that maintains and supports patient breathing. The device, which offers both invasive and non-invasive options, can assist adult and pediatric patients.
Manufactured for GE Healthcare, the Centiva/5 has three major components: the main engine, control panel, and expiration valve. This software-controlled system offers volume-regulated, pressure-regulated, and spontaneous ventilation modes.
Only physicians or qualified medical professionals should operate the Centiva/5. A maintenance check for safety and proper function is suggested every 12 months.
The Centiva/5 is a compact ventilator that comes with two detachable display options.
Dimensions for 6.5-inch Display
- Height: 21 cm/8.3 in
- Width: 26 cm/10.3 in
- Depth: 29 cm/11.4 in
- Weight: 13 kg/28.7 lbs
Dimensions for 12-inch Display
- Height: 32 cm/12.6 in
- Width: 32 cm/12.6 in
- Depth: 32 cm/12.6 in
- Weight: 14.7 kg/32.3 lbs
The device has flexible placement options and a backup battery.
Technical Specifications
Physical Specifications
Centiva/5 with 6.5 inch Display
- Footprint: 25 x 24 cm/9.8 x 9.4 in
Centiva/5 with 12 inch Display
Ventilator Operating Specifications
Controls and Ranges
- FiO2: 21 to 100%
- Rate: 4 to 100 bpm
- Inspiratory/expiratory ratio: 4:1 to 1:9.9 VCV, SIMV-VC, 9.9:1 to 1:9.9 Bi-Level mode
- Tidal volume range: 20 to 2,000 mL
- Set pressure limit: 10 to 60 cm H2O
- Max. inspiratory pressure limit: 70 cm H2O
- PEEP/CPAP: Off to 35 cm H2O
- Set inspiratory flow: 2 to 99.9 L/min
- Max. inspiratory flow: ~180 L/min (120 L/min continuous flow)
- Inspiratory plateau: 0 to 75% of inspiration time, as a resulting parameter
- By-flow: 3 to 30 L/min
- Inspiratory pressure: 1 to 59 cm H2O
- Pressure Support (PS) level: 0 to 59 cm H2O
- Pressure Support Ramp: 0.1 to 0.5 seconds
- PS end flow: 10 to 60% of peak PS flow
- Trigger sensitivity: 0.5 to 20 L/min
- Trigger time window: 20 to 90% of expiration time
- Bi-Level ramp: 0.1 to 3 seconds
Ventilation Modes
- VCV, aVCV
- SIMV-VC
- Bi-Level
- Apnea Backup
- CPAP/PSV
Ventilator Monitoring
- Airway pressure: -9 to +90 cm H2O
- Patient flow: -150 to +200 L/min
- Tidal volume: 0 to 2,500 mL, resolution 1 mL
- Minute volume: 0 to 99 L/min, resolution 0.1 L/min
- Rate Spont: 0 to 200 breaths per minute
- O2 Inspiratory: 0 to 100%
- Peak pressure: -9 to 90 cm H2O
- Plateau pressure: -9 to 90 cm H2O
- Mean airway pressure: -9 to 90 cm H2O
- Pmin: -9 to 90 cm H2O, measured
- PEEP: -9 to 90 cm H2O
- Resistance: 1 to 99 cm H2O/L/s
- PEEPi: -9 to 90 cm H2O (measured during exp Pause)
- RSBI: 1 to 999
Source: Ventilator Operating Specifications
Additional Information
GE Healthcare Centiva/5 Critical Care Ventilator Magazine
