Battery
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting Page
For common problems with the controller, refer to the PSKONTORORA LBER-P4-05 Troubleshooting page.
Background
The PSKONTORORA LBER P4-05 is a cheap alternative for the PlayStation 4 controller. Produced by PSKONTORORA, it is advertised as being the top-rated P4 controller and as having the same features as an original PS4 controller. It has the all-standard aspects on a PS4 controller: D-pad, same button pattern, top bumpers and a share button. A very similar controller but it has the added feature of programmable rear buttons for extra control in some games, adding to overall efficiency. All of this is possible with the 1000mAh battery that has 15 hours of working time, 2 hours of charging time, and 30 days standby period.
Unfortunately, little else is known on the controller or even the company that manufactures it. From what we know, our model was first available on August 7, 2023 with a newer, slightly upgraded version coming out only a few months later in December 23, 2023, with that model coming with an upgraded touchpad feature.
Identification
The PSKONTORORA LBER-P4-05 is a handheld controller that can be paired to a PlayStation 4. It has a white center that transitions into a dark blue, followed by a white stripe and an even darker blue. It has different button icons compared to a normal PlayStation controller. Instead of the normal square, triangle, circle, and x, it has a somewhat different variation, with it using smaller shapes to create the recognizable shapes.
Technical Specifications
Size: 5.91 x 3.94 x 1.57 inches
Weight: 306.17 g (10.8 oz)
Battery capacity: 1000mAh
Battery type: Lithium
Charging type: USB Type-C
3.5mm audio jack
6-axis gyro sensor
38.2 ft wire connection range
