6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
VX10.2XLPROR
Background and Identification
This product is a tile saw manufactured by Pearl Abrasive. Tile saws, also called ceramic tile cutters, are used to cut ceramics into specific shapes. The VX10.2XLPROR uses a 10 inch diameter diamond blade that can cut tile up to 3 and 1/4 inches deep. This tile cutter is large enough to cut 24” by 24” tiles for rip cuts (cuts that are parallel to the ‘grain’), and 18” by 18” tiles for angle cuts (cuts that are not parallel to the ‘grain’). Tile saws can also be run wet or dry. This model is run ‘wet’, which means that it uses water as a coolant on the blade to keep it from overheating as it cuts.
Technical Specifications
- Item: VX10.2XLPRO
- UPC: 662333179107
- Motor: 2 HP, 115 V / 60 Hz, single phase
- Speed: 3,450 rpm
- Max Depth of Cut: 3-1/4"
- Rip Cut Capacity: 24" x 24" tile
- Angle Cut Capacity: 18" x 18" tile
- Blade Capacity: 8" - 10" with 5/8" arbor size
- Thermal Overload Protection: Yes
- Arbor Shaft Rotation: Counterclockwise
- Width: 22 1/2”
- Length: 24”
- Height: 19 1/4”
- Weight: 84 lbs
- gfci plug part# v35018
- extension cord part # v35019
