1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
83200
Background
The Qep Tile Saw 83200 is a tool designed for cutting a variety of materials, including tile, marble, granite, porcelain, and stone. It was initially introduced to the market in September 2004. The 83200 model is a bridge saw designed for wet cutting applications. It is equipped with a 1 HP 3420 RPM brushless motor, intended to provide a smooth and steady performance. The tile saw is engineered to evenly distribute water flow, aiming to extend the lifetime of the diamond blade. It includes a ball bearing cutting assembly that is intended to facilitate smooth scoring and clean cuts.
The tile saw requires a 120V power source and consumes 1100 watts of power. It features a 24" diamond blade that operates at 3420 RPM. The 83200 model weighs 90.39 lbs and has product dimensions of 44.1 x 24.41 x 48.43 inches. The model's cutting capacity is for a 24-inch tile. It is multicolored and the blade is made from high-speed steel.
Technical Specifications
- Brand: QEP
- Color: Multicolor
- Blade Material: High Speed Steel
- Surface Recommendation: Tile
- Power Source: Corded Electric
- Special Feature: Brushless
- Voltage: 120 Volts
- Item Weight: 90.39 lbs
- Speed: 3420 RPM
- Blade Length: 24 inches
- Wattage: 1100 watts
- Part Number: 83200Q
- Product Dimensions: 44.1 x 24.41 x 48.43 inches
- Item Model Number: 83200Q
- Motor: 1 HP direct drive brushless
- Cutting Capacity: 24 inch tile
Warranty
The QEP 83200Q 24" Bridge Saw is covered by a 1 year limited warranty. This warranty is effective upon product registration and covers defects in both materials and workmanship. In order to make a warranty claim or order replacement parts, users are required to contact QEP directly at the provided phone number, which is 561-994-5550.
