4 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
RD68011
Background
The Ridgid RD68011 is a generator that was released in 2016. It is designed to be portable, making it ideal for various uses including construction sites, emergency home backup power, and recreational activities where a power source is needed. The generator is equipped with a 389cc engine and produces 6,800 starting watts and 5,500 running watts. It operates on gasoline, with a fuel tank capacity of 6.6 gallons, enabling it to run for up to 12 hours at 50% load.
The RD68011 generator has several features to enhance its functionality and reliability. It has two 120V 20A household outlets and one 120/240V 30A locking outlet. It is designed with overload protection and low oil automatic shutdown to prevent damage. The generator also includes a digital ignition system for convenient starting. Furthermore, the unit has a steel frame and wheels that do not go flat, enhancing its portability. The generator weighs 191 lbs and its dimensions are 27" x 29" x 25.5".
Technical Specifications
- Model Number: RD68011
- Product Type: Portable Generator
- Engine: 389cc OHV
- Starting Watts: 6,800
- Running Watts: 5,500
- Fuel Type: Gasoline
- Fuel Tank Capacity: 6.6 gallons
- Runtime: Up to 12 hours at 50% load
- Voltage Output: 120V, two 120V 20A outlets and one 120/240V 30A outlet
- Safety Features: Overload protection, low oil shutdown, digital ignition
- Noise Rating: 76 dBA from 23 feet
- Weight: 191 lbs
- Physical Dimensions: 27" x 29" x 25.5"
- Frame: Steel with never-flat wheels for portability
Warranty
The Ridgid RD68011 generator comes with a 3-year limited warranty. This warranty covers defects in materials and workmanship, but it's important to note that it is limited to non-commercial use. Meaning, if the product is used commercially, the warranty may not apply. To claim the warranty, it is typically required for the user to provide proof of purchase, so it's recommended to keep any receipts or invoices. If a defect is identified within the warranty period, the user should contact Ridgid customer service for further instructions on how to proceed with a warranty claim.
