2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
CSB133L
Background
The Ryobi CSB133L is a circular saw that is primarily used for cutting wood or composite lumber and sheet goods. It operates using a corded electric power source and is equipped with a 7-1/4 inch carbide-tipped blade that is powered by a 13 amp motor, capable of achieving up to 5,000 RPM. This machine is known for its ability to make straight, cross or rip cuts.
The Ryobi CSB133L has several key features that enhance its cutting ability and user experience. The bevel has an adjustable capacity of up to 51 degrees, which allows for compound miter cuts. It also has an Exactline laser alignment system which aids in achieving more precise cuts, and a spindle lock for more efficient blade changes. The saw comes with ergonomic handles for a more comfortable grip. It is powered by a corded electric source and runs on a standard 120V AC outlet. The saw weighs 7.35 lbs, and measures 12 in. x 9.5 in. x 7.5 in.
Technical Specifications
- Motor: 13 amp motor with up to 5,000 RPM
- Blade: 7-1/4 in. carbide-tipped blade with 20 teeth
- Bevel capacity: Adjustable up to 51 degrees
- Cut depth at 90°: 2.438 in.
- Cut depth at 45°: 1.875 in.
- Features: Exactline laser alignment system, spindle lock for blade changes, ergonomic handles, onboard wrench storage
- Power source: Corded electric, 120V AC, 6 ft cord
- Dimensions: 12 in. x 9.5 in. x 7.5 in.
- Weight: 7.35 lbs
Warranty
The Ryobi CSB133L circular saw is sold with a three-year limited warranty. This warranty coverage includes any defects that may arise from the materials used or the workmanship of the product, but is only valid for three years from the date of purchase. Notably, this warranty is limited to the repair or replacement of the product and does not extend to cover normal wear and tear, misuse, or accidental damage. To maintain the validity of the warranty, it is essential that the saw is properly cared for and maintained.
