6 Diagrams
Models
RYI2300VNM
Background
Ryobi's Inverter Generator RYI2300VNM 2020 Model is a small and portable device. This model has 2,300 starting watts and 1,800 running watts, and is extremely quiet at all times while turned on. The generator can connect to almost any smartphone to monitor the power consumption, fuel level, run time left, and turn off the generator all with the GENControl app. The generator does use Bluetooth technology to connect to nearby phones for the GENControl app. This model also has parallel capabilities to link together two RYOBI inverter generators for double the output if needed for large power demands.
The generator has had no recalls as of 2022 with no major problems being reported or found.
Identification
The RYOBI Generator stands 19 inches high with a width of 12.5 inches and a length of 22 inches. This generator is the classic RYOBI green with a black trim and a LCD display screen on the front to monitor details about the fuel level and runtime remaining. The front of the device also has 2 USB slots and 2 normal plug in slots. The auto idle button will also be found right above the LCD screen. It has two rear wheels for easier portability and handles on the top, front, rear and bottom of the generator. You can find the product's model number on a sticker on the lower side of the generator.
Technical Specifications
- 2,300 Starting Watts
- 1,800 Running Watts
- Very Quiet
- FREE RYOBI GENControl app: monitors fuel level, power consumption, and runtime remaining all on your smartphone
- Remote Shutdown capable
- Board LCD Display
- Fuel efficient auto- idle energy saving technology
- Extremely portable: dual rear wheels, suitcase handle, front and rear handles
Sources:
