3 Diagrams
Models
RY14122
Background
The Ryobi RY14122 is a residential electric pressure washer. It is primarily used for cleaning purposes in areas such as driveways, decks, windows, and other parts of the home.
The specifications of the pressure washer include a pressure capacity of 1,700 PSI and a flow rate of 1.2 GPM. It is powered by a corded electric source through a 13 AMP motor, with a power cord length of 35 ft. The device has a high pressure hose length of 25 ft and a detergent tank capacity of 0.6 gallons. Its weight is 27 lbs, and the dimensions are 18 x 18 x 19 inches.
The Ryobi RY14122 features a roll cage frame design which provides upright stability and protection for its internal components. It has an on-board 0.6 gallon detergent tank for soap application, a 25 ft non-marring high pressure hose, quick connect spray tips, and includes three types of nozzles: 0°, 15° and a turbo nozzle. The turbo nozzle increases the cleaning power in a cone pattern. Additionally, it has on-board storage for spray tips and accessories and utilizes a maintenance-free aluminum pump.
Technical Specifications
- Pressure: 1,700 PSI
- Flow rate: 1.2 GPM
- Power source: Electric (corded)
- Motor: 13 AMP
- Power cord length: 35 ft
- High pressure hose length: 25 ft
- Detergent tank capacity: 0.6 gallons
- Weight: 27 lbs
- Dimensions: 18 x 18 x 19 inches
Warranty
The Ryobi RY14122 pressure washer offers a 3-year limited warranty, which covers any defects in the materials or workmanship of the product. However, it is important to note that this warranty does not extend to damages resulting from misuse, abuse, or normal wear and tear. If you need to claim this warranty, you should contact the manufacturer directly, providing details of the defect and proof of purchase. It is advisable to keep all original purchase receipts and documents to facilitate this process.
