Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Note:
If you have a Saeco coffee maker, also take a look at the guides for Philips and Gaggia machines. They are all made by the same manufacturer and have a very similar design. Some components are identical in many cases, such as the pump, drain valve, heater or motor.
Background and Identification
The Incanto Classic is an automatic espresso machine designed by the Italian coffee machine company Saeco. The device is mostly made from stainless steel and comes in silver and black colors. You can identify this model by looking for the words “Incanto” and “Classic” written on the left side of the front of the device. There are a few other models in Saeco’s Incanto line of products including the Rondo, the De Luxe, and the Sirius.
The Incanto Classic has a receptacle for coffee beans on the top with a grinder that you can adjust to fine-tune the degree to which the beans are ground. The machine also has a secondary chute for pre-ground coffee powder and an override button for using this input. On the front of the Classic there is a rotatable steam nozzle which produces steam quickly thanks to a separate boiler in the device. The front side also has the nozzle where brewed coffee pours out. The nozzle uses the Saeco Brewing System (SBS) to allow you to choose the strength of the coffee by twisting a single knob. You can attach a spout attachment to the nozzle which will split the output into two streams for two cups at once.
The main component inside the Incanto Classic is the brew group, which is the heart of the machine. You can remove it easily by opening up the front case. In case it goes bad, you can find replacements online.
Technical Specifications
Grinder
  • 8 gram coffee grinder
  • Adjustable grinding degree
  • Pre-ground powder chute
Water
  • Removable water tub
  • 2 liters (68 ounces)
  • Rapid steam
Output nozzle
  • SBS (Saeco brewing system) to adjust coffee strength
  • Two nozzles
  • Adjustable height
  • Removable
Features
  • Removable brewgroup
  • Descaling program
Additional Information
Saeco Incanto Classic official support page
Saeco Incanto Classic manual
Saeco Incanto Classic service manual
Incanto Classic SBS specifications from Bean2Cup
Incanto Classic review by Seattle Coffee Gear
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 103
All Time: 13,497
