LCD Display Panel
2 Answers 3 Score |
Why is my machine leaking water. Why does it shut off |
1 Answer 0 Score |
My machine îs seeyng that my servis door îs open but îs closed properl |
1 Answer 0 Score |
Circuit board main transistor replacement |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
If you have a Saeco coffee maker, also take a look at the guides for Philips and Gaggia machines. They are all made by the same manufacturer and have a very similar design. Some components are identical in many cases, such as the pump, drain valve, heater or motor.
Background and Identification
Released in 2012, the Saeco Intelia HD8752 is a high-end automatic espresso machine produced by Philips. With its stainless steel design, the HD8752 has a high-quality look and provides greater durability for a long-lasting performance. Moreover, the HD8752 has ceramic grinders that allow for a consistent grind without overheating the coffee bean—avoiding the burnt taste. The ceramic choice also aids in the machines long-lasting performance and allows for silent operation.
Technical Specifications
- Espresso technology:
- Saeco adapting system
- Aroma-system: pre-brewing
- Supported coffee types:
- Ground coffee
- Whole coffee beans
- Water pressure in pump: 15 bar (perfect espresso)
- Removable brewing group: Yes
- Country of origin:
- Designed in Italy
- Made in Europe
- Cord length: 80 cm
- Number of water boilers: 1 boiler
- Power: 1850 W
- Boiler material: Stainless steel (Inox)
- Cleaning and maintenance:
- Automatic coffee circuit rinse
- Descaling cycle
- Usage:
- Adjustable coffee dispenser
- Cup holding surface
- Rapid steam
- Normal/long espresso option
- Product weight: 8.9 kg
- Water tank capacity: 1.5 L
- Maximum cup height: 130 mm
- Product dimensions (L x D x H): 256 x 340 x 440 mm
- Coffee bean capacity: 300 grams
- Waste container capacity: 10 servings
- Features:
- Cappuccinatore
- Brews seven coffee varieties
- Stainless steel
- Automatic milk frother
- Hot water/ Steam Nozzle
- Simultaneous brewing
- Brita Filter compatible:
- Optionable
- Yes
- Cappuccinatore
- Color: Stainless Steel/Balck
- Materials and finishing: Stainless Steel/ Plastic
- Energy saving: Automatic stand-by
- Service: 1-year guarantee
