Antenna Board
3 Answers 2 Score |
Screen replaced but screen not working - external monitor works |
1 Answer 1 Score |
Not charging after update |
1 Answer 0 Score |
Replaced broken and then tablet died |
1 Answer 0 Score |
Black screen even after replacing |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
SM-T978U (5G US)
Background
The Samsung Galaxy Tab S7+ 5G was announced on September 2nd, 2020 and released on September 18th alongside a Wi-Fi only version and the Tab S7 base model. This iteration of Samsung’s tablet line features a 12.4-inch 20 Hz Super AMOLED screen, a Snapdragon 865 processor by Qualcomm, and 5G capabilities. Marketed as being a functional laptop replacement, the Tab S7+ comes with an S pen; the keyboard, however, is an additional $199.
The Samsung Galaxy Tab S7+ 5G starts at $899 for the 128 GB/8 GB RAM version and comes in Mystic Silver, Mystic Black, and Mystic Bronze colors.
Technical Specifications
Versions:
- SM-T970 (Wi-Fi only)
- SM-T976B (LTE/5G)
Physical Specifications:
- Dimensions: 285 x 185 x 5.7 mm (11.22 x 7.28 x 0.22 in)
- Weight: 575 g (1.27 lb)
- Build: Glass front, aluminum back, aluminum frame
Battery:
- Li-Po 10090 mAh, non-removable
Display:
- Super AMOLED, 120Hz
- HDR10+
- 12.4 inches, 446.1 cm2 (~84.6% screen-to-body ratio)
- 1752 x 2800 pixels, 16:10 ratio (~266 ppi density)
Processor:
- Chipset: Qualcomm SM8250 Snapdragon 865 5G+ (7 nm+)
- CPU: Octa-core (1x3.09 GHz Kryo 585 & 3x2.42 GHz Kryo 585 & 4x1.8 GHz Kryo 585
- GPU: Adreno 650
OS:
- Android 10
- Upgradable to Android 12
Memory:
- microSDXC (dedicated slot)
- 128 GB 6 GB RAM, 256 GB 8 GB RAM, 512 GB 8 GB RAM
Camera:
- Main Camera:
- 13 MP, f/2.0, 26mm (wide), 1/3.4", 1.0µm, AF
- 5 MP, f/2.2, 12mm (ultrawide), 1.12µm
- HDR, panorama
- 4K@30fps
- Selfie Camera:
- 8 MP, f/2.0, 26mm (wide), 1/4", 1.12µm
- 1080p@30fps
Connectivity:
- WLAN: Wi-Fi 802.11 a/b/g/n/ac/6, dual-band, Wi-Fi Direct, hotspot
- LTE/5G
- Bluetooth: 5.0, A2DP, LE
- GPS: Yes, with A-GPS, GLONASS, BDS, GALILEO
- NFC :No
- Radio: No
- USB: USB Type-C 3.2, magnetic connector
