Battery
1 Answer 2 Score |
My watch won't turn on |
1 Answer 0 Score |
Water proofing after repair |
1 Answer 0 Score |
How to open samsung galaxy watch 3 bezel |
1 Answer 1 Score |
Power Off option is popping up without the button being pressed |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
41mm SM-R850 (Wi-Fi Only), 41mm SM-R855F (Global LTE), 41mm SM-R855U (USA LTE), 45mm SM-R840 (Wi-Fi Only), 45mm SM-R845F (Global LTE), 45mm SM-R845U (USA LTE)
Specifications
Release date: August 2020
Model:
SM-R845F, SM-R855F (Global, LTE model);
SM-R855U, SM-R845U (USA, LTE model);
SM-R850, SM-R840 (Wi-Fi only)
Dimensions:
- 45 mm version:
- 46.2 × 45 × 11.1 mm (~ 1.82 × 1.77 × 0.44 in)
- 41 mm version:
- 41.9 × 45.7 × 12.7 mm (~1.65 × 1.8 × 0.5 in)
Weight:
- 45 mm version:
- 53.8 g without strap
- 41 mm version:
- 48.2 g without strap
Display :
- 45 mm version:
- 1.4 in (34 mm) circular Super AMOLED
- 360×360 pixel resolution (~392 ppi)
- 41 mm version:
- 1.2 in (30.5 mm) circular Super AMOLED
- 360×360 pixel resolution (~424 ppi)
- Gorilla® Glass DX+
Operating System:
- Tizen Based Wearable OS 5.5
Processor/Chipset:
- Exynos 9110 Dual core 1.15GHz
RAM/Storage:
- 1 GB RAM + 8GB Internal Memory (RAM capacity may vary depending on model, color and country)
Battery:
- 45 mm version:
- Li-Ion 340 mAh
- 41 mm version:
- Li-Ion 247 mAh
- Qi wireless charging
Sensors:
- Accelerometer
- Barometer
- Gyro Sensor
- Electrical Heart Sensor(ECG)
- Optical Heart Rate Sensor(HRM)
- Light Sensor
3.5mm headphone jack: no
Wireless Connectivity:
- 802.11 b/g/n 2.4GHz Wi-Fi
- Bluetooth® 5.0
- NFC
- LTE and UMTS (only for LTE models)
- A-GPS/ GLONASS/Beidou/Galileo
Durability:
- 5 ATM + IP68
- MIL-STD-810G
Compatibility:
- Samsung, other Android: Android 5.0 or higher & RAM 1.5GB above
- iPhone: iPhone 5 and above, iOS 9.0 or above
