1 Answer 1 Score |
How do you test your battery to see if it is failing |
1 Answer 0 Score |
Band pin knob broken off |
Background
The Galaxy Watch 6 Classic is an Android smartwatch developed by Samsung in 2023.
It contains 16 GB of internal storage and 2 GB RAM.
Identification
This smartwatch comes with different color options for each size:
- 43 mm: Silver, Black
- 47 mm: Silver, Black
Specifications
Sizes: 43 mm or 47 mm
Display:
- 43 mm:
- Super AMOLED Full Color Always On Display
- 1.3" (33.3mm) 432 x 432
- 47 mm:
- 1.5”, 480 by 480 pixels, ~330 ppi density
Platform:
- Exynos W930 (5 nm) chipset
- Dual-core 1.4 GHz Cortex-A55 CPU
- 2GB RAM + 16GB Internal Memory
Operating System: Android Wear OS 4, One UI Watch 5
Sensors: Samsung BioActive sensor (optical heart rate + electrocardiac trace + bioelectrical impedance analysis), temperature sensor, accelerometer, barometer, gyroscope, geomagnetic sensor, brightness sensor
Battery:
- 425 mAh (44 mm), 300 mAh (40 mm)
Wireless Connectivity:
- LTE
- GPS, GLONASS, GALILEO, BEIDOU, NFC
- Wi-Fi 2.4+5 GHz
- Bluetooth 5.3
Miscellaneous Features:
- Water-resistant/Dust-resistant 5ATM+IP68/MIL-STD-810G
- Qi wireless charging
- BioActive Sensor for body composition measuring
- Holistic sleep analysis
