Display
1 Answer 1 Score |
Need to replace my cracked screen |
2 Answers 2 Score |
How can I reinstall NC110 totally block out |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Features
Designed to Perform
Perfectly equipped and designed to keep you connected, entertained and looking stylish, the NC110 has a sleek, clean design of rich black exterior and black interior. With an island-style keyboard, a larger separation is provided between individual keys allowing easier, faster typing, emailing and web surfing with fewer typing errors. And with a weight of 2.73 lbs, it’s portable enough to go to school, work or anyplace in-between.
Astounding Battery Life
Get mobility and the freedom to work, play or surf the web without worrying about battery life. The 6 cell battery of the NC110 stays charged for up to 10.7 hours* and has a 250GB hard drive so you can bring everything you need with you.
*Battery life will vary depending on the product model, configuration, power management settings, applications used, and wireless settings. The maximum capacity of the battery will decrease with time and use. Test results based on independent third party testing.
Easy Connectivity
Connect anywhere via a wired LAN or the wireless 802.11b/g/n connection. Bluetooth 3.0 and a 4-in-1 media reader are included. And Allshare™ technology makes it simple to connect to multiple Samsung devices, to easily search for and control content through your NC110.
Power Back up in 3 Seconds with Fast Start
You no longer have to shut down your Samsung computer, just close its lid and it goes into a special powerless sleep mode. When you open the lid your computer comes back to life in 3 seconds and you are exactly at the same place as when you shut the lid. Fast Start saves your data and system configurations to your hard drive and PC memory. So, when you power it back on it is just like you left it.
''Natural and Realistic 3D Sound
''Using the NC110’s HD audio, you can hear your music, movies and games with more natural and realistic 3D SRS Premium Sound™. The NC110 provides enhanced bass, crystal clear dialog and better definition control for maximum clarity at high frequency.
