5 Answers 15 Score |
Write protected pendrive issue |
4 Answers 1 Score |
Can the data on this cracked SanDisk flash drive be recovered? |
4 Answers 1 Score |
Broken stem on pcb SanDisk Cruzer Blade |
3 Answers 1 Score |
chromebook recovery utility not unzipinng file |
Documents
Background and Identification
The Cruzer Blade is a USB flash drive designed by SanDisk. It comes in capacities of 8 GB, 16 GB, 32 GB, 64 GB, and 128GB. The flash drive is made from plastic shaped into a rounded case with a USB plug on one end. The drive can transfer data at USB 2.0 speeds (480 Mbit/s) once you plug it in.
The Cruzer Blade can be identified by the product name printed on one side of the device, while the opposite side typically bears the SanDisk logo in white or red text. It was produced in various colors, such as green, blue, purple, white, and black. The black version stands out with a red plastic accent, while the other models are made of a single color of plastic.
Technical Specifications
Capacity
- 8 GB, 16 GB, 64 GB, 128 GB
Interface
- USB 2.0 Type A male plug
Dimensions
- Length: 1.63 inches (41.5 mm)
- Width: 0.69 inches (17.6 mm)
