Battery
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Shark Wandvac Power Pet WV410 is a cordless, handheld vacuum. It was designed with pet owners in mind and can clean up hair and debris in smaller areas. This device comes with a charging stand and a few accessories to help you get into hard-to-reach places. It comes with a traditional and boosted suction mode, which offers better performance but takes up more energy.
It utilizes a high-speed brushless motor capable of picking up pet hair and other debris. It is operated by two buttons, a power and boost button, on the top of the vacuum. On the underside, you will find a yellow button and access to the easy-to-clean dust collection area. It is powered by a single lithium-ion battery that can run for up to 17 minutes on a full charge.
Shark produces a variety of other handheld “Wandvac” models, ranging from the WV200 to the WV400 series. They share many traits, such as being cordless and handheld, which allows users to clean up small areas quickly with ease. Shark has not issued any issues or recalls since the introduction of this model of Shark handheld vacuums.
Identification
The Shark Wandvac Power Pet WV410 is a cordless, handheld vacuum weighing approximately 1.5 pounds (0.7 kg) and 15.4 inches (39.1 cm) in length. This device comes in dark blue and dark purple (violet). You can tell the Shark Wandvac WV410 apart from other vacuums in the WV400 series by the two buttons and lack of power indicators. In the WV410 model, only two main buttons are present: the power and boost mode. The underside of the vacuum has a yellow slide button that releases the dust cover. On the other end of the device, you will find the lithium-ion battery.
Technical Specifications
- Product Dimensions: 2.7 in L x 2.4 in W x 15.4 in H
- Cleaning Path Width: 7.6 in
- Dust Cup capacity: 0.1 quarts
- Filter Type: Fabric filter
- Wattage: 160 watts
- Hazmat Class/Battery Cell Type: UN3481 – Lithium Ion Battery with or in Equipment
- Voltage: 14.4 volts
- Weight: 1.48 lbs
- Model Number: WV410
Source: Shark Power Pet WV410 Product Page
