1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
SPT77WM
Background
The Skil Circular Saw SPT77WM is a tool used to cut through materials with a round, rotating blade. It is a 7-1/4 inch worm drive circular saw, a technology that has been part of Skil's production line since the 1920s. The design of this model aims to be lighter and more efficient than its predecessors.
This circular saw is characterized by its weight of 11.5 lbs and a magnesium housing which is intended to lower the tool's weight while maintaining resilience. Its motor is specifically engineered to suit worm drive saws and is designed to maintain a cooler temperature during extended periods of use. The Skil SPT77WM runs on 120V power and has a 15 amp current rating. It comes with a 7-1/4 inch 24 tooth blade made of high-speed steel, known as the Diablo blade.
Technical Specifications
- Model Number: SPT77WM
- Product Type: Circular Saw
- Weight: 11.5 lbs
- Housing Material: Magnesium
- Power Source: Corded Electric
- Voltage: 120V
- Amperage: 15A
- Blade Length: 7.25 inches
- Blade Tooth Count: 24
- Dimensions: 9.5"L x 20.75"W x 8"H
- Blade Material: High speed steel
- Additional Items: Includes multi-functional wrench
Warranty
The Skil Circular Saw SPT77WM is covered by a 1-year limited warranty along with a 180-day "Stay True" guarantee. The limited warranty covers defects in materials or workmanship for a period of one year from the date of purchase. The "Stay True" guarantee, active for 180 days from the date of purchase, ensures the product will function as promised. To claim either of these warranties, it is usually required to keep the original purchase receipt as proof of purchase date. Always check with the manufacturer's warranty terms and conditions for the exact process of claiming warranty.
