Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Background and Identification
The Smiths Medical 1818E is a pulse oximeter made by Smiths Medical. Pulse oximeters are non-invasive devices used to monitor a patient’s oxygen saturation. Smiths Medical is a designer and manufacturer of medical devices for general anesthesia, respiratory care, cardiology, pain management, and other medical areas.
The 1818E pulse oximeter is designed to measure the patient’s pulse rate and oxygen saturation. It can be used in clinical, hospital, or transport environments. This model is compatible with all BCI, Inc. oximetry sensors and can be used for adult, pediatric, and neonatal patients. The patient’s pulse rate and oxygen saturation are displayed on the monitor’s LED displays. An eight-segment LED bar graph present’s the patient’s pulse strength. When the patient’s finger is removed from the oximetry sensor, the monitor automatically turns off to save battery life. The 1818E model can optionally connect to an external printer or computer which can provide data logs and spot-check printouts of oxygen saturation and pulse rate.
The 1818E weighs just nine ounces without batteries and is designed to fit in the palm of an adult’s hand. It is powered either by three standard alkaline batteries (type LR 14) or three rechargeable (type KR27/50) “C” cell batteries. In the oximeter’s continuous mode, the batteries can last up to 24 hours. In spot-check mode, the batteries can last up to 80 hours. Low-battery indicator lights alert the user when approximately two hours of battery use remains.
Technical Specifications
Equipment Classification:
- Type of Protection Against Electric shock: Internally Powered
- Mode of operation: Continuous
- Degree of Protection Against ingress of Liquids: IPX1, drip-proof
- Degree of Mobility: Portable
- Degree of Protection Against Electric Shock: Type B
- Safety Requirements: EN60601-1; 1990
Displays, Indicators, & Keys:
- SpO2: LED numeric display, 0.43 inches (10.9 mm) high
- Pulse Rate: LED numeric display, 0.375 inches (9.5 mm) high
- Pulse Strength: Logarithmically scaled 8-segment LED bargraph
- Keys: I & O keys
SpO2:
- Range: 0-99%
- Accuracy:
- ±2% at 70-99%
- ±3% at 50-69%
- Averaging: 8 pulse beat average
- Display Response The display is to functional saturation. The pulse strength bar graph is not proportional to pulse volume.
- Display Update Rate: 1 Hz (SpO2); 60 Hz (pulse strength)
- Calibration: Factory calibrated over range 50% to 100% SpO2 using human blood samples to functional saturation. Test methods available upon request. No in-service calibration required.
- Sensors
- Red: 660nm, 2mW (typical)
- Infrared: 905nm, 2-2.4mW (typical)
Pulse Rate:
- Range: 30-254 BPM
- Accuracy: ±2% at 30-254 BPM
- Averaging: 8 second average
Auxiliary Printer Output:
- SpO2 and pulse rate values can be output every five (5) seconds (data log). Data saved every thirty (30) seconds can be printed (spot-check).
Power Requirements:
- Uses three standard alkaline (type LR 14) or nickel-cadmium “C” cell batteries (type KR27/50).
- Battery Life: Approximately 24 hours in continuous mode or 80 hours in spot check mode.
Dimensions:
- Width: 3.25 inches (82.6 mm)
- Height: 6.3 inches (160 mm)
- Depth: 1.25 inches (31.75 mm)
- Weight: 9 ounces (255 grams) without the batteries
Environmental Specifications:
- Operating Temp.: 0-55° C (32-131° F)
- Storage Temp.: -34-70° C (-29-158° F)
- Relative Humidity:
- 10-95% (storage), non-condensing
- 15-95% (operating), non-condensing
