Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Background and Identification
The Smiths Medical 1850 is a pulse oximeter made by Smiths Medical. Pulse oximeters are non-invasive devices used to monitor a patient’s oxygen saturation. Smiths Medical is a designer and manufacturer of medical devices for general anesthesia, respiratory care, cardiology, pain management, and other medical areas.
The 1850 model measures the patient’s oxygen saturation and pulse rate. It is designed for use in hospital, clinical, home, or air/land transport environments. This model is compatible with all BCI, Inc. oximetry sensors and can be used for adult, pediatric, and neonatal patients. The pulse rate and oxygen saturation are displayed on an LED display with user-adjustable brightness.
This monitor produces visible and audible alarm signals when measured values move outside of user-defined limits. Users can operate the pulse oximeter in three modes, Clinician Mode, Home-Use Mode, and Sleep Study Mode. In Clinician Mode, health care professionals can monitor patient activity. The Home Use Mode allows caregivers to monitor patients in their homes. The Sleep Study Mode allows health care professionals to record sleep study data that can be transferred to a computer.
The 1850 pulse oximeter includes an internal, rechargeable battery that can last up to 24 hours on one full charge. The battery fully charges in six hours. A low-battery indicator light displays when 30-minutes of battery use remains.
Technical Specifications
Oximeter
Parameters Monitored: SpO2, Pulse Rate, Pulse Strength
Displays, Indicators, & Keys:
- SpO2: 3-digit LED display, 0.43 inches (10.9 mm) high.
- Pulse Rate: 3-digit LED display, 0.375 inches (9.5 mm) high.
- Pulse Strength: Logarithmically scaled 8-segment LED bar graph.
- SENSOR; Sensor alert indicator.
- BATT: Low battery indicator.
- Silenced: Alarm and alert tone silenced indicator.
- Keys: Nine control keys provided.
- Brightness: Adjustable brightness of SpO2, pulse rate, and bar graph displays.
Indicators:
- POWER: Indicates oximeter connected to AC power.
- CHGING: Indicates oximeter battery is charging.
SpO2:
- Range: 0-100%
- Accuracy:
- ±2% at 70-100%
- ±3% at 50-69%
- Alarm Limits
- High 100-50% and off in 1% steps.
- Low 50-99% and off in 1% steps.
- Averaging: 4, 8, or 16 pulse beat average.
- Sensors
- Red: 660nm, 2mW (typical)
- Infrared: 905nm, 2-2.4mW (typical)
Pulse Rate:
- Range: 30-254 BPM
- Accuracy: ±2% at 30-254 BPM
- Alarm Limits:
- High 250-5 BPM and off in 5 BPM steps.
- Low 5-250 BPM and off in 5 BPM steps.
- Averaging: 8 or 16 second average.
Alarm Indicators: Two-tone audible alarm with user-adjustable volume and two-minute or indefinite alarm silence. Corresponding numeric display flashes.
Sensor Alert Indicator: Single-tone audible alarm with same volume and silence as alarm tone.
Printer Output: Data saved every thirty (30) seconds can be printed (trend).
Battery:
- Type: Internal rechargeable NiCad or NiMH; not user-replaceable.
- Charge Time:
- Nicad: Fully charges in about 4 hours.
- NiMH: Fully charges in about 6 hours.
- Use Time: Approximate continuous use:
- 12 hours (Nicad)
- 24 hours (NiMH).
- Indicators: BATT indicator lights when about 30 minutes of battery use remains.
- AC Charger: Wall Mount Style:
- Input of 105-125 V~, 60Hz
- Input of 100V~, 50Hz (Optional)
- Table Top Style: Input of 230 V~, 50/60Hz
Dimensions:
- Width: 3.3 inches (84 mm)
- Height: 7.25 inches (184 mm)
- Depth: 1.85 inches (47 mm)
- Weight: 19 ounces (539 grams) including battery
Environmental Specifications:
- Temperature:
- Operating:-20-55° C (-4-131° F)
- Storage: -40-75° C (-40-167° F)
- Relative Humidity:
- Operating: 15-95%, non-condensing
- Storage: 10-90%, non-condensing
