Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Background and Identification
The Steris AMSCO 3085 General Surgical Table is a mobile, electrohydraulically operated surgical table that can support nearly all general surgical procedures including cardiac and vascular, endoscopic, gynecology, urology, nephrectomy, neurology, ophthalmologic, and orthopedics with the use of additional Steris table accessories. The 3085 model is designed with hand controls that quickly perform table movements to properly position the patient.
Sometimes known as a surgical table, operating tables are typically used within an operating room or surgical suite of a hospital, ambulatory surgery center, or other healthcare facilities where surgeries are performed. Operating tables may be either stationary or mobile to move room to room. Operating tables are used in various types of procedures such as cardiothoracic, orthopedic, bariatric, robotic, urologic, and more.
The Steris AMSCO 3085 surgical table includes bariatric width extenders that stretch the table to 28 inches to accommodate the width of up to a 1,000-pound patient. Without the extenders, the surgical table is 20 inches wide and 76 inches long with a height range between 27 and 44 inches. In the side tilt and reverse orientations, the patient weight capacity is 500 pounds.
Steris also sells over 300 surgical table accessories to accommodate many surgical specialties. The 3080 General Surgical Table is sold in three models, a battery-powered version, an electric-powered version, and a voice-activation capable model.
Technical Specifications
Table Top Length: 76" (193 cm)
Table Top Width: 20" (508 mm) (28" with extenders)
Table Height Range: 27" to 44" (686 to 1118 mm)
Patient Weight Capacity:
- 1,000 lbs (454 kg) normal orientation
- 500 lbs (227 kg) side tilt & reverse orientation
Table Shipping Weight:
- 918 lbs (416 kg) electric-powered
- 920 lbs (417 kg) battery-powered
- X-ray tops add 40 lbs (18 kg) to shipping weight
Upper Body Imaging Area
Normal orientation (28" x 16"): 448 sq in (2890 cm2)
Normal orientation with IA extender (36" x 16"): 576 sq in (3716 cm2)
Reverse orientation, head section reversed (45" x 16"): 720 sq in (4645 cm2)
Reverse orientation, 36" carbon fiber fluoro extension (36" x 20"): 720 sq in (4645 cm2)
Lower Body Imaging Area
Normal orientation (33" x 14"): 462 sq in (2980 cm2)
Normal orientation, head section reversed (45" x 16"): 720 sq in (4645 cm2)
Normal orientation, 36" carbon fiber fluoro extension (36" x 20"): 720 sq in (4645 cm2)
Normal orientation with Fem/Pop board (55" x 16"): 880 sq in (5678 cm2)
Hand control features
- Normal/reverse orientation button
- Return to level button
Trendelenburg / Reverse: 25° / 25°
Lateral Tilt (left/right): 18° / 18°
Head Section: +90° to -90°
Back Section
- +55° to -25° (normal)
- +80° to -105° (reverse)
Leg Section
- +80° to -105° (normal)
- +55° to -25° (reverse)
Flex/Reflex: 20° / 25°
Manual Override: Yes
Perneal Cut-out: Yes
Kidney Elevator: 4" (10 cm) manual
Models Available
- Battery-powered
- Electric-powered
- Voice-activation capable
